Hawks 17X9 Formula '88-92 Reproduction - finally!
#51
COTM Editor
Received 1,921 Likes
Car: '89 Firebird
Engine: 7.0L
Re: Hawks 17X9 Formula '88-92 Reproduction - finally!
When you put WIDER AFTERMARKET wheels on the car, WIDER THAN STOCK, then the wheel and tire can start to bump things. Especially things like tie rods, sway bar (front of tire), and the inner fender liner (rear of tire). Proper backspacing helps with all these issues. Think of the spacer as an adjustment to wheel backspacing.
And, yes, not all 3rd gens have the same width between front wheel hubs. Some are wider than others. And people with late model brake swaps also have extra width because they're stacking the new rotor hub on top of the stock rotor hub.
#52
Car: 90 Formula / T-tops
Transmission: MD8
#54
Transmission: MD8
Those other options probably already exist for other rims types, such as Trans Am wheels, so they are probably just giving you options. As far as I know, Formula's only came with the one Airwolfe posted.
Airwolfe (07-14-2024)
#55
Location: Franklin, KY near Beech Bend Raceway, Corvette Plant and Museum.
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
I don't remember the 88 to 92 PE0 Hi- Tech Deep Dish Formula wheels being anything other than sliver lug nut caps, sliver center cap with sliver emblem with black WS6 wording.
#57
Engine: 4++,350 & 305 CIs
Im guessing it's these, no i didn't measure but I'd guess its a 1/4 less thread engagement. Drove fine and no signs of loose lugs in the bit i drove it. (120mph)
https://www.hawksmotorsports.com/r15...s-motorsports/
#58
Car: '91 Firebird Formula
Engine: SP383 Deluxe FIRST® TPI Intake
Transmission: Tremec T56
Axle/Gears: Moser 9" Eaton Truetrac Motive 3.89
Great! Thanks!
I'm not too concern in straight line. Put a brick on the accelerator and it'll go fast in straight line... not lateral G's involved. Anyone can do that!
I'm thinking about hard cornering, braking and hard launch... like I do
From my own perspective, I would not accept 1/4" less thread engagement, unless I can measure and there is enough thread engagement left.
For a M12X1.5, you need minimum 8 turns, IIRC.
#59
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
Just unboxed my white 91-92 wheels. Very impressed with how they were packaged, great job to the crew @ Hawks.
I'll post up some pics on the car once I get the General G-Max AS 07 tires mounted.
The following 3 users liked this post by STREETDEMON:
#60
COTM Editor
those look great! need to get a set for my 91z vert!
#62
Car: 91 Z28
Engine: 6.0L LQ9
#64
At the Pontiac nationals this weekend
The following 6 users liked this post by TTOP350:
91formula_WS6_5 (07-20-2024), Buddy (07-22-2024), jayg (08-19-2024), Jaysz28 (07-23-2024), SbFormula (07-22-2024), and 1 others liked this post.
#65
Dub post
#67
He brought all 3 stages to norwalk. They were running my friends stage 2 car (black). It went 10.40s @ 139mph, theres more in it for sure. I'm guessing a 9.80 car with that mph.
#71
COTM Editor
Car: '89 Firebird
Engine: 7.0L
COTM Editor
Car: '89 Firebird
Engine: 7.0L
That white Camaro looks fantastic!
STREETDEMON (07-23-2024)
#74
On a 1990 Formula with the stock 10.5" Delco-Moraine brakes, with Koni Yellow Struts, with UMI Bump Steer Adjuster Kit with Hawks 17x9 Trans Am/GTA style wheels had to use the included spacers to mount the front wheels.
On a 1989 Turbo TA with the stock 12" 1LE front brakes with Hawks 17x9 Trans Am/GTA style wheels did not have to use the included spacers to mount the front wheels. Did have to be selective with which wheel and tire set got mounted on the front because the lazy mount & balance guy didn't get the Yellow dot on the tires aligned with the valve stems on all wheel and tire sets and didn't try rotating the tires on the wheel to try to get a better balance with less or no wheel weights. Some had stick on wheel weights mounted close to the outside edge on the inner wheel barrel and would slightly rub making a tick, tick, tick sound. Rubbed just barely enough to make a sound but not enough to knock the weight off.
The rotor thickness in the hub area on a 1LE rotor is much thicker than the rotor thickness in the hub area on a stock Delco-Moraine rotor. So a 1LE rotor pretty much has its own spacer built in to it.
#76
Inner front wheel wells. The Ronal factory when it was in Orange County, told me I wouldn't need spacers. But after reading this, I have stock brakes and not the 1LE's. So, spacing has been an issue. I'm going to start driving my car again soon, so I can report back if this was the culprit all along. Live and learn.
#77
Keep in mind that 3rd gens had different steering boxes with different internal steering stops and different front lower control arms with different steering stops depending on which wheel and tire combo was installed from the factory.
3rd gens with the 16x8 245/50 16 wheel and tire combos had more restrictive steering stops that wouldn't let you cut the tires as hard and even they still would rub the tires on an full lock turn like when getting in and out of a very tight spot in a parking lot.
If the car you are talking about the Ronals rubbing on is your 87 Camaro LT I'm guessing it came with 15x7 wheels and 215 wide tires. It wouldn't had had the more restrictive steering stops.
#78
#79
Oh they were that small. I'm a Firebird guy and mainly 89+ so I was just taking a guess at the 87 Camaro LT wheel and tire size. With that small a combo you could probably turn them sideways in the fender well. LoL
Yeah with a stock steering box and lower control arms on your LT the stops on it won't be anywhere near as restrictive as say a 16x8 245/50 16 WS6 car.
Also I was somewhere on the forum within the last few days and read a post by a user with the Ronals and he said the spacers are a must with them even with 1LE brakes. IDK if they were real 17x9.5 Ronals or reproduction 17x9 Ronals.
cypris09
Exterior Parts for Sale
04-05-2017 07:05 AM
Linson
10-04-2015 12:08 PM
Red WS6 Ram Air
02-16-2004 08:09 PM
