Camaro 10 spoke wheels
Car: 1991 camaro z28 convertible
Engine: 5.0 v8
Axle/Gears: 9 bolt 3.23 borg worner
I picked up a set of Camaro 10 spoke wheels, does any one know if they are axle specific I installed them on the car and one of the front tires stick out almost 2 inches farther then the other side. any info helps thanks in advance
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Camaro 10 spoke wheels
They should all be the same. You can rotate them assuming you don't have unidirectional tires.
Engine: 5.0 v8
Car: '90 RS
Engine: 377 LSX
Engine: 5.0 v8
the front passenger side tire sticks out 2 inches farther then the driver side tire does, took the car for an alignment and found out the issue then don’t know how I didn’t notice it when I put them on
Car: '90 RS
Engine: 377 LSX
What spacers are you running? Are you sure they are the same spacer on each side?
Engine: 5.0 v8
Car: '90 RS
Engine: 377 LSX
Take the wheels off and start investigating. Take some measurements and try to rotate the wheels around. Double check your spacers to make sure you don't have a front on a rear and vice versa.
Engine: 5.0 v8
