Front tire size
Old 05-20-2018, 07:33 PM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Front tire size
Alright guys, I am looking for some info on front tire size. I just got my new wheels and will be running a 295 40 18 on the rear but would like to know if anyone is running a 275 40 18 on the front? Not sure if that will be any rubbing issues. I was thinking about a 275 35 18 on the front but worry the sidewall will look too small.
Old 05-21-2018, 07:29 PM
TGO - 10 Year Member
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Front tire size
No, use the 35 series. The 275/40 is 26.6 tall and is too much for the front
Rear should be 295/35/18, which is 26" tall and will match the front
Old 05-21-2018, 07:55 PM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Re: Front tire size
The 40 series fits the rear perfect. I had a 245 45 18 on the front with no issues. Was hoping to stay away from the 35 series. Not a fan of the rubber band sidewall. Bit if i dont have a choice i guess i will have to go that route.
Old 05-21-2018, 08:20 PM
//<86TA>\\'s Avatar
Re: Front tire size
Then aspect ratio, the 2nd number of the tire size is a precentage of the width, it's not an actual number so a 35 series tire can have a taller sidewall than a 40 depending on the width of the tire.
For example my rear tires are 335/30/18 but have a taller sidewall than a 245/40/18
Old 05-21-2018, 08:22 PM
//<86TA>\\'s Avatar
Re: Front tire size
A 245/45/18 is a taller tire, but is also skinny so it's not as problematic as a wider tire of the same height. Buy what you want, but there is a good chance the 275/40 will rub the wheel openings when turning
Old 05-21-2018, 08:36 PM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Re: Front tire size
I get the percentage of the sidewall. I was just trying to keep the overall diameter close. My rears are 27" tall. I just didnt think going down to a 25.5" front tire would look right.
Old 05-21-2018, 09:02 PM
//<86TA>\\'s Avatar
Re: Front tire size
Give the 275/40 a try then. Since you have 18" wheels, you can pull them in further than 17" and smaller since the tie rod will clear the wheel. If the wheels are more inboard, they will be less likely to rub.
Provided you are already using spacers and can use thinner ones
Old 06-03-2018, 10:29 AM
kestell123's Avatar
Car: 1991 camaro convertible
Engine: LS3
Transmission: 6l80
Axle/Gears: Ford 8.8 3.31 torsen t2r
Re: Front tire size
I run 275-40-18 front and rear for my street tires,slight rubbing at full lock [parking lot turns]. A little better ride than my autocross tires that are 275-35-18. Part of those choices were about what sizes the tires I wanted for each purpose were available in.
Old 06-03-2018, 10:54 AM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Re: Front tire size
I think i will give the 40 series a try then. I will be running a weld rts 18x9 with a 6.1" backspacing so it will bring the tires in a bit. I assume you are running a 9.5 or larger front rim?
Old 06-03-2018, 08:15 PM
kestell123's Avatar
Engine: LS3
Transmission: 6l80
Re: Front tire size
On the front I am using 9.5 x 18 c5 corvette wheels with 1.5 inch spacers, I have the c4 13 inch brake conversion which moves the wheel mounting surface out about half an inch.
Old 06-03-2018, 08:48 PM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Re: Front tire size
Any chance you have a pic of them on the car? I have 2018 camaro 4 piston brembos going on the front and the conversion also pushes the wheels out .375"
Old 06-05-2018, 04:04 PM
kestell123's Avatar
Engine: LS3
Transmission: 6l80
Re: Front tire size
I try to post pics
Old 06-05-2018, 04:06 PM
kestell123's Avatar
Engine: LS3
Transmission: 6l80
Re: Front tire size
The rear is fourth gen width.with no spacers
Old 06-05-2018, 04:24 PM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Re: Front tire size
Thanks for the pics. What is the back spacing for your front wheels?
Old 06-05-2018, 07:32 PM
kestell123's Avatar
Engine: LS3
Transmission: 6l80
Re: Front tire size
According the OE wheel web site it is 7.38
Old 06-05-2018, 08:15 PM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Re: Front tire size
My wheels should sit about the same as yours then. Thanks.
Ozz1967
11-08-2010 06:21 PM
Mcdamit
12-02-2005 06:10 PM
iroczrockz
11-06-2004 10:26 PM
86FirebirdV8350
05-31-2003 05:38 PM
Quick Reply: Front tire size
