Wheel adapters
Old 11-09-2015 | 11:09 AM
bamaboy0323's Avatar
Wheel adapters
So after changing my mind 2000 times on what wheels I want to get for my vert I've finally decided and purchased them. they are 18x9.5 et20 offset but 5x114.3 bolt pattern CB 73.1. I know I need adapters but my question is would 1" adapters be the sweet spot for this setup? Will I need hubcentric rings as well?
I am also wondering if I can run 275\40's on all 4 corners. I have a 1 inch drop on eibach pro kit springs.
Old 11-16-2015 | 11:17 AM
lt1z350's Avatar
Car: 92 formula, sd,730ecm with $59
Engine: 383/ t-76 turbonetics
Transmission: 700r4 3200 vig converter
Re: Wheel adapters
Sort of doing same thing and looking at enkei raijin. The company selling said for our car to run a 18x9.50 36mm offset 114.3 then get the adapters in 20-26mm with the lug conversion. Sounds about correct to me with what I have been reading. Now just need to decide on the damn rim. Lol what did u go with? Camaro or firebird? Color? I have a 1992 formula in red and deciding between the black or silver to go with red. Just hard to decide on style without seeing on car. I also have ctsv brakes all the way around so have to consider that on my wheel choice. Ugh.
6speedIROC
02-07-2016 02:42 PM
Maadi
Wheels and Tires
11-20-2015 02:38 AM
sriley69
Alternative Port EFI Intakes
10-19-2015 03:19 PM
InfernalVortex
10-03-2015 07:40 PM
hookin88formula
03-04-2001 10:46 PM
Quick Reply: Wheel adapters
