17 X 9.5 Sawblades with 3" Spacers?
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: 17 X 9.5 Sawblades with 3" Spacers?
i would consider a different wheel. 3in spacers are sketchy. but you should be good there with that size spacer if you really wanted those wheels.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
3" is 76mm, or 20m more than you would need to get 56mm 9.5" width wheels to fit. They will stick out about 1".
Also having a hard time finding them in 2.25 and 70.5 center bore though
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
the new wheels are 17" and since the strut is on an angle in relation to the wheel the clearance from the strut to the wheel will increase with larger diameter wheels.
