Tires with more grip!
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
I have the futura gls sport tires, 245/60/15 in the rear. They have no grip whatsoever!
Are there any good tires that I can get some good grip in? These slid all over the place
Car: 64'olds 442, 87 Formula 350
Engine: 350 tpi
Axle/Gears: 3.27 borg warner 9 bolt
Re: Tires with more grip!
I run bfg gforce sport comp 2s, excellent summer tire
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Mainly street, occasional track hardly ever drive it in the rain. It's to the point where I'm not comfortable taking any corners while on the gas. From a dead stop I get no traction anywhere past 1/4 throttle, 1st or second gear roll wot it just burns the tires.
Don't get me wrong it's fun to be able to break the tires loose so easily but sometimes I feel like I'm losing so much acceleration because the tires suck.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
245-60-15 is not a size that is popular, nor is there any real choices for street tires - not much in 235-60-15 either.
Are you willing to move up to a 16" or 17" wheel and tire combo?
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
I love the irocz 16 inch rims, torq thrust, corvette wheels are nice, either 16 or 17 inch rims are fine
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
In that case, look at 17" due to the availability of tires in 245-45-17 and 275-40-17 sizes (245-50-16 is pretty much dead).
And if you buy new wheels (not 2nd hand), go for a 9.5" wheel that will allow you to run a 275-40 in all 4 corners - huge improvement in all around grip.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
^ that's what's on mine now. 17x9.5 with 275/40/17 bfg g force sport comp II.
Haven't got to try them yet but looking forward to it.
I've ran the old version sport comp and liked them.
Transmission: Pro-built 700R4
Another vote for Bfg sport comp g force. Been running them for close to a decade now.
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Good. In that case, look at 17" due to the availability of tires in 245-45-17 and 275-40-17 sizes (245-50-16 is pretty much dead). And if you buy new wheels (not 2nd hand), go for a 9.5" wheel that will allow you to run a 275-40 in all 4 corners - huge improvement in all around grip.
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
ill add that i like the bfg sport comp II they hold pretty well once they have some heat in them. reasonably priced as well
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
In 245-50-16, the only choice of tires for high performance use is the BFG G-Force Sports.
Huge difference in handling moving up from 16" to a wider 17" tire.
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
depends on the sizes http://www.tirerack.com/tires/tires....e+Sport+COMP-2
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
