Need some pictures of Camaros with 19 inch wheels
Old 09-12-2013 | 01:53 PM
Mr. McGuire's Avatar
Car: 91 Camaro Z28
Engine: 305 V8 (5.0L) TPI
I know there is a tread similar but couldn't find it.
Ok so I found the wheels I want but just need to know how 19s look on a third gen. A few people have said they are too big but I just want to check. I'm trying to build a pro tour or autocross style car not 100% for comp use just forchaving that style mainly. Really just want a nice looking car too. If you think the 19" wheels are going to effect the performance negatively please let me know.
Another thing is I'm afraid of rub between the tires and car, I have Eibach springs and didn't get struts yet and the springs will drop the car 1.7 in the front and 1.3" in the back. I plan on low profile tires for traction so that will help the clearence I hope.
If someone has a black camaro on black 19" wheels that would be an even bigger help. Otherwise any Camaro or Bird with 19s should do.
Thanks guys!
Old 09-12-2013 | 02:11 PM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: Need some pictures of Camaros with 19 inch wheels
you should be fine with clearance even lowered, 19x8 with 245-35-19 rubber will clear fine, with no need to change speedo gear
Old 09-12-2013 | 06:40 PM
BADNBLK's Avatar
COTM Editor
You can run a 19" wheel is you want. There have been article showing that the lower aspect ratio of large diameter tires does affect the grip in performance driving. An 18" wheel will open more doors for selection of wheels, and cost... same with tires.
I would do a lot of research before running off and putting on a 19x8 wheel, and 245's... if you really are gonna autox it.
Old 09-12-2013 | 09:18 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
A 245-35-19 tire will not be any more competitive in autocross than a 245-40-18 or a 245-45-17 one.
Thirdgens as front heavy RWD platforms need a lot of tire under the corners to handle well on autocross - 275 is a good starting size, 285 or wider is better.
Keep in mind that a 19" wheel and tire combo will weigh more than a 17" or 18" equivalent and with a much stiffer sidewall (which will bump the effective spring rate way up).
Old 09-13-2013 | 06:39 AM
Car: 91 Camaro Z28
I don't plan on really using it for competition use. Its just that style I really like both for the performance characteristics and looks. I plan on using more to travel long distances for example, I live in Pa and want to drive west to places in Texas and Arizona. I heard theres a great muscle car scene in those areas. So pro tour is more what I'm looking for.
Old 09-13-2013 | 11:59 AM
paul_huryk's Avatar
Ok, understood.
19" is an oddball size for the most part, 18" and 20" are super popular with the PT crowd. That said, 19" and above have very small tire sidewalls and will be a problem with rutted northern roads, plus the ride will suffer.
That said, I would suggest a set of 18" wheels all around for both style and performance. An 18" x 9.5" wheel with a 275-35-18 tire is a huge step up from a 245-40-18 one in terms of visual impact and performance for virtually the same money.
Old 09-13-2013 | 12:06 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
19x8 and 19x10
Old 09-14-2013 | 06:34 PM
Car: 91 Camaro Z28
That's a great looking Iroc. I think I know what I'm getting, pretty much settled on 19s. The car being lowered like that and wheels tucked under looks amazing. NufNuffZ28, what tire sizes are you using?
Old 09-16-2013 | 12:33 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
265/285
Old 09-16-2013 | 12:42 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Mickeys street radial II here, 305/35/19. Looks great with the taller sidewall, fills the wheel well up and superb traction lol just sucks its 375$ a tire
Old 09-17-2013 | 12:25 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
19x8.5 245/40 19 19x9.5 275/35 19 I will be getting 255/35 and 285/30 tires soon
Frozer!!!
01-19-2024 05:55 PM
Vintageracer
01-10-2020 06:33 PM
colton_carlson
03-08-2019 01:21 PM
Scorched1984
Wheels and Tires
66
04-16-2016 07:56 PM
greeny
Wheels and Tires
08-12-2015 04:55 PM
