My new wheels. 17x9 & 17x10 OG San (cross-lace style)
#51
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 91 Camaro Z28
Engine: 5.0L LB9 305 TPI
Transmission: 5 spd
Axle/Gears: 3.42 Rear End
Re: My new wheels. 17x9 & 17x10 OG San (cross-lace style)
robertfrank, jazzdadss, Holmes and GTA777 thanks for the compliments on the wheels.
Those do look great......bout time someone made some bigger replicas
Actually a 275-40-17 is a better/exact fit size for a 17x9 wheel....(stock 4 gens w/17's have 275's on them)....
But with a 9 front and 10 rear to really get that staggered look you can do a 255-45-17 front and a 285-40-17 rear. They both are 25.94 in. tall (stock 3rd gen 16's are 25.7).....and a 285 will fit better on a 10" wheel....
check out the Nitto 555's.... http://www.nittotire.com/Tire/nt555#size
I have Boyd Codington Magnito's 17x8 F with 245-45-17 and 17x10 R 315-35-17....
just my
brdofpry85ta thanks for the input I am still deciding on the tire measurements (I want to get it right). I will take a look at the above stated. I already had the 555s in mind as well as the Falken FK452s.
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
just my
![my 2 cents](https://www.thirdgen.org/forums/images/smilies/twocents.gif)
#52
1 Post
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
I always thought our rims bolt pattern were 5 X 120 and not 5 X 120.65. Due to the mm, which is very small, would the rim not fit on our cars? I found a dealer in Canada who can get these for me and was about to purchase them but want to make sure these would fit.
Thanks.
Thanks.
#53
Car: 91 Trans Am GTA
Sorry for being a newbie about this.
Thanks for your help.
#54
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I always thought our rims bolt pattern were 5 X 120 and not 5 X 120.65. Due to the small variance, .65 mm, which is very small, would the rim not fit on our cars? I found a dealer in Canada who can get these for me and was about to purchase them but want to make sure these would fit.
Thanks.
Thanks.
#55
These are awesome, just changed my mind for wheels, these will retain my stock appearance as well and will look great with the stock beige color top!!
#56
KXWheels in Richmond (I think) BC. $275 for 17 X 10s. Google KXWheels. They don't have it on their website, only the 15" 4 bolt ones. I contact them and they said the rims are new which is why they're not on the site. I was talking with Gabe.
#57
Car: 89 GTA
Now is it worth it to swap...
#58
Threw on a set of OG San wheels on my Z28. I had to have these wheels because I love the lip in the rear and the fact that they are a 17 x 10. I got in touch with Axis Wheels and they made it happen. I'm stoked.
The set up up front is a 17x9 +10 with a 1in spacer and rear is 17x10 +15 with an 8mm spacer.
![](http://i988.photobucket.com/albums/af3/jc_olague/null-2.jpg)
![](http://i988.photobucket.com/albums/af3/jc_olague/null-4.jpg)
![](http://i988.photobucket.com/albums/af3/jc_olague/null-1.jpg)
![](http://i988.photobucket.com/albums/af3/jc_olague/null.jpg)
![](http://i988.photobucket.com/albums/af3/jc_olague/null-3.jpg)
#59
1 Post
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Dude, my thoughts, exactly!!! We need these in 18" with the CORRECT backspacing and bolt pattern
#60
1 Post
If I don't get an email response from them by Tuesday, I will make some phone calls and see if they can help us out. Lets see if they can build them and what kind of pricing they are talking about. And yes, if we could do 18" or 19" even and proper offsets to avoid spacers and wider tires too would be awesome. I do want to emphasize the center hub diameter to utilize our factory center caps though and also want to find out if they can be made without the bolts at the outer ring of the wheel to the barrel area.
#61
1 Post
Allright, I'm gonna be a tool and reply a 3rd time. I think it's not cool that these guys aren't willing to make these in 18 inches, especially considering there is an existing market for them and that people are already purchasing the 17 inch version.
P.S.
Downshift,
Isn't there a spacer available that adapts your GM bolt patern to the BMW bolt pattern?
P.S.
Downshift,
#62
Car: 85 iroc z
Engine: 355 tpi
Transmission: 7r4
very nice just bought my iroc a few weeks ago looking for some wheels love the look of those
#63
Car: 91 Camaro Z28
Transmission: 5 spd
I'm sure you can have a 1" spacer drilled to 5x120 => 5x120.65 to use on this wheel in regards to the front two. However, for the rear you just need an 8 mm spacer so there is no bolt patter correction there. I am using a 5x120 => 5x120 1" spacer in the front and a 4 mm in the rear on my current setup, I have not had any problems (18" TSW Valencias)....
#64
Car: 91 Camaro Z28
Transmission: 5 spd
Update:
I decided to go with Sumitomo HTR Z IIs. 245/45 in the front and 275/40s in the rear. They got mounted today and I have to say I really liked the way they fit. I got that "donut" look without having to stretch the tires. I hope to put them on the car this weekend.
![Name: null-9.jpg
Size: 145.5 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/345088d1501329937-my-new-wheels-17x9-null-9.jpg)
![Name: null-11.jpg
Size: 83.7 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/345089d1501329937-my-new-wheels-17x9-null-11.jpg)
![Name: null-9.jpg
![Name: null-11.jpg
![Name: null-10.jpg
Size: 125.3 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/345090d1501329937-my-new-wheels-17x9-null-10.jpg)
#65
1 Post
That's hot!!!!
Man, I just wish they had these rims in 18 inches with the right backspacing
#67
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I can't see the pics, but I'd love to see them, can you repost them??
#68
Car: 91 Camaro Z28
Transmission: 5 spd
#70
Car: 91 Camaro Z28
Transmission: 5 spd
IROCgiraffe I will try and upload some shots once the wheels are on the car (by Sunday I hope). Hopefully they will not look too bulky.
#71
Nice wheels! Cool looking car all around.
#73
Car: 91 Camaro Z28
Transmission: 5 spd
Width & height comparison of the rear wheels and tires. Old set up and new set up as well as pic of the spacer used in the rear, 8mm or 5/16. **NOTE** The rear will require longer wheel bolts to compensate for the spacer. I’m going to be getting some ARP extended studs soon.
![Name: null-12.jpg
Size: 154.5 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/344996d1501329705-my-new-wheels-17x9-null-12.jpg)
![Name: null-13.jpg
Size: 123.3 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/344997d1501329705-my-new-wheels-17x9-null-13.jpg)
![Name: null-14.jpg
Size: 72.9 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/344998d1501329705-my-new-wheels-17x9-null-14.jpg)
Width & height comparison of the front wheels and tires. Old set up and new set up as well as pic of the 1” spacer used in the front.
![Name: null-17.jpg
Size: 132.0 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/344999d1501329705-my-new-wheels-17x9-null-17.jpg)
![Name: null-16.jpg
Size: 158.3 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/345000d1501329705-my-new-wheels-17x9-null-16.jpg)
![Name: null-15.jpg
Size: 84.2 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/345001d1501329705-my-new-wheels-17x9-null-15.jpg)
Now…the mounted wheels.
![Name: null-24.jpg
Size: 126.1 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/345002d1501329705-my-new-wheels-17x9-null-24.jpg)
![Name: null-26.jpg
Size: 85.3 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/345003d1501329705-my-new-wheels-17x9-null-26.jpg)
![Name: null-30.jpg
Size: 124.2 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/345004d1501329705-my-new-wheels-17x9-null-30.jpg)
![Name: null-29.jpg
Size: 131.2 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/345005d1501329705-my-new-wheels-17x9-null-29.jpg)
![Name: null-28.jpg
Size: 64.1 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/345006d1501329705-my-new-wheels-17x9-null-28.jpg)
![Name: null-12.jpg
![Name: null-13.jpg
![Name: null-14.jpg
![Name: null-17.jpg
![Name: null-16.jpg
![Name: null-15.jpg
![Name: null-24.jpg
![Name: null-26.jpg
![Name: null-30.jpg
![Name: null-29.jpg
![Name: null-28.jpg
![Name: null-31.jpg
Size: 133.8 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/345007d1501329705-my-new-wheels-17x9-null-31.jpg)
#74
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
![](http://i988.photobucket.com/albums/af3/jc_olague/null-12.jpg)
![](http://i988.photobucket.com/albums/af3/jc_olague/null-13.jpg)
![](http://i988.photobucket.com/albums/af3/jc_olague/null-14.jpg)
![](http://i988.photobucket.com/albums/af3/jc_olague/null-17.jpg)
![](http://i988.photobucket.com/albums/af3/jc_olague/null-16.jpg)
![](http://i988.photobucket.com/albums/af3/jc_olague/null-15.jpg)
![](http://i988.photobucket.com/albums/af3/jc_olague/null-24.jpg)
![](http://i988.photobucket.com/albums/af3/jc_olague/null-26.jpg)
![](http://i988.photobucket.com/albums/af3/jc_olague/null-30.jpg)
![](http://i988.photobucket.com/albums/af3/jc_olague/null-29.jpg)
![](http://i988.photobucket.com/albums/af3/jc_olague/null-28.jpg)
![](http://i988.photobucket.com/albums/af3/jc_olague/null-31.jpg)
#75
Car: 89 GTA
Axle/Gears: 4.10
Do you think the rears will hit the fender lip if you bottom out? They look like the stick out just slightly more than stock.
![](http://s21.postimg.org/i2c17fcp3/IMG_0628.jpg)
#76
Car: 91 Camaro Z28
Transmission: 5 spd
It is hard to tell by just looking at it because it is so close. If I was to lower the car or was worried about bottoming out I would go with a thinner spacer. I will check like in the picture you posted.
![Name: null-27.jpg
Size: 132.4 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/344983d1501329680-my-new-wheels-17x9-null-27.jpg)
#77
Car: 89 GTA
Axle/Gears: 4.10
Good view on that pic, looks like you should be in the clear! I really like the rims, I'd get gold ones for my black GTA, but I don't want to hide my Baer calipers
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
#78
1 Post
need. these. wheels. in. 18inches. with. proper. backspacing.
they. look. so. good.
Good job guys!
The irony is, usually it's us GTA guys that cry for crosslace wheels, and here, we have two camaro guys leading from the front!
Good job guys!
#79
1 Post
Car: Too many cars
So with a 4th gen rear you wouldnt need a spacer? Would a 17x10 fit the front? Can we just order a set not painted?
#80
Car: 1989 Turbo Trans Am
Engine: 3.8L Turbo
Ordered these wheels for my TTA yesterday, can't wait to see how they look on the car. I went a little different on the sizing and I'll post the details and pictures once we get them on the car.
#81
Car: 91 Camaro Z28
Transmission: 5 spd
Awsome! Yeah post the pics. I'd love to see them on a TTA and I'm sure a lot of others would too. I'm guessing you went 17x10 all the way around?
#82
Car: 91 Camaro Z28
Transmission: 5 spd
I'm not sure if they are a direct fit to the 4th gen F body rear end on the 3rd gen F body combo. I would think that the 17x10 would work on the front but am not 100% sure. I do not belive you can order a raw set, but you can always have them customized as there are many shops out there that mod wheels.
#86
Car: 91 Camaro Z28
Transmission: 5 spd
#87
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Downshift, your car looks amazing! Loving the new rims and tires, very good choices.
#88
Car: 1988 Trans Am GTA
Transmission: TH-7004R
Car: 91 Camaro Z28
Transmission: 5 spd
Oh wow guys. Thank you so much for the great comments. It really helps motivate this build.
#90
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I have 275/40 on a 9.5" Ron, they fit great no bulging sidewall.
#91
Car: 91 Camaro Z28
Transmission: 5 spd
I decided on these tires when I saw user kevin91z's fire hawks and the tire size he had on. I really like the way they fit.
#92
Car: 91 Camaro Z28
Transmission: 5 spd
Got the longer wheel studs installed.
![Name: null_zps172dfe74.jpg
Size: 167.6 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/343467d1501326433-my-new-wheels-17x9-null_zps172dfe74.jpg)
![Name: null_zpsa5cdbe95.jpg
Size: 68.8 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/343468d1501326433-my-new-wheels-17x9-null_zpsa5cdbe95.jpg)
![Name: null_zpsdad4dd89.jpg
Size: 182.1 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/343469d1501326433-my-new-wheels-17x9-null_zpsdad4dd89.jpg)
![Name: null_zpsfe7b5fa6.jpg
Size: 83.1 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/343470d1501326433-my-new-wheels-17x9-null_zpsfe7b5fa6.jpg)
#93
Car: 91 Camaro Z28
Transmission: 5 spd
At a show
![Name: null_zps26c39755.jpg
Size: 105.8 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/343241d1501325913-my-new-wheels-17x9-null_zps26c39755.jpg)
![Name: null_zps8d668c66.jpg
Size: 126.0 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/343242d1501325913-my-new-wheels-17x9-null_zps8d668c66.jpg)
#95
Car: 91 Camaro Z28
Transmission: 5 spd
#96
1 Post
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Wow man you car looks amazing. I want a set so bad but Ive wanted a set of ronals for so dam long. I would want these but I dont want to run a spacer as I want to do alot of track stuff and a spacer just isnt ideal for that. Still I mightpull the trigger on a set just to have them for driving around on. If you dont mind me asking is it a 3rd or 4th gen rear in your car?
#97
Car: 91 Camaro Z28
Transmission: 5 spd
#98
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
First off thanks for bringing these to our attention! I just picked up a set for my GTA.
Will be having them mounted tomorrow.
Do we really need extended wheel studs for the 8mm spacer? These cars came with an 8mm spacer from the factory on the stock wheels in the back & the lugnuts thread of their fine. Is this just something extra you wanted to do?
#99
#100
