So whats the biggest size we can go
Old 04-29-2013 | 02:10 AM
Lmancha96's Avatar
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
I am interested in purchasing some 19x10 wheels but I am not sure if that will fit without any major modifcation.
Also how much modification would it take to fit 19x12?
Old 04-29-2013 | 03:20 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: So whats the biggest size we can go
Old 04-29-2013 | 09:01 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Yes topic has been covered. 19x12 wont fit without minitub work and offset lca's. 10" wide will fit and you can fit a 305 tire no taller than 27.5". I run a 305/35/19 mickey drag radial and its tight fit with alot of hammering work to inner well.
Old 04-30-2013 | 03:45 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
The real question is what size tire do you want to run. You can fit a 19x12 without any modification with a stretched tire and lower offset. But I'm pretty sure 99% of the people on this site aren't that open minded.
Old 04-30-2013 | 01:40 PM
Lmancha96's Avatar
Engine: LB9|TPI
Continue.. I am a very open minded person..
Old 04-30-2013 | 01:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Please dont. Stretched tires are the dumbest thing to hit the car scene and i dont care what ppl say, they dont seem safe to me
Old 04-30-2013 | 02:14 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Been doing a lot of research on this lately. Biggest you can go with the "Straight sidewall" look is about 10". Maybe 10.5" if your offset is perfect. Biggest rear tire without a lot of hammering (Assuming your wheel is just right.) is about 295/30/19.
I'm going with 19X8.5 front and 20X9.5 rear with 255's in the front and 295's in the rear. That's a lot of tire.
Jason.
Old 04-30-2013 | 11:07 PM
Lmancha96's Avatar
Engine: LB9|TPI
Jason.
Thanks for sharing this dude... really appreciate it
Old 04-30-2013 | 11:09 PM
Lmancha96's Avatar
Engine: LB9|TPI
After using google to see some images of stretched tires I have come to realize that I may not be as open minded as I thought lol...
Yeah that look is not for me...
Old 04-30-2013 | 11:10 PM
Lmancha96's Avatar
Engine: LB9|TPI
Thanks Im definitely going to go with
18x8.5/19x10 and 275/45 all around
Old 05-01-2013 | 12:15 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
There is a guy on the board with an awesome black 90 iroc vert and he went through the rear tire project and his car is awesome. I think he posted a lot of great info on that if memory serves.
Old 05-14-2013 | 03:15 PM
jdogg89iroc-z's Avatar
Car: 89 iroc-z, 2010 camaro ss
Engine: 383 stroker
Axle/Gears: 9 bolt 2.73
I'm running 275s on front and 315s on rear of my 89 iroc
Old 05-14-2013 | 05:18 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Please don't confuse size (wheel diameter) with actual dimensions of the tire that rests upon the road. There is no difference in contact patch of a 245-50-16 sized tire and a 245-40-18 sized one in the same pattern - but there are differences in tire sidewall, weight, perceived spring rate, and handling & ride characteristics.
Old 06-10-2013 | 07:17 PM
dwhess504's Avatar
LOL at the stretched Tires I havent heard about it before and googled it as well and was like WTF?!
Pac J
05-17-2020 11:44 AM
LiquidBlue
Wheels and Tires
32
12-10-2019 05:06 PM
BrianChevy
Wheels and Tires
10-13-2015 01:33 PM
dbrochard
Interior Parts Wanted
09-28-2015 08:40 PM
Twinn Engines
South East Region
09-25-2015 07:25 AM
