Bent rim... :( is it ruined?
Car: 1986 IROC-Z/28
Engine: LB9 TPI
So the VERY edge of my IROC rim is bent up a little bit at a 90 degree angle. The affected area is TINY, is there any way I can bend it back in place? (imagine taking a paper disc (rim) and bending one cm in from the edge).
Need more info? ask
Need more info? ask
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Bent rim... :( is it ruined?
It will probably crack or break if its bent back. To fix it correctly will require welding and refinishing
ZZ3Astro
08-13-2019 12:57 AM
TOMcat GTA
09-15-2015 09:31 AM
