http://www.ebay.com/itm/Epsilon-Wheels-/271153370075?hash=item3f220013db&item=2711533
Car: 1991 Z28
Engine: 350 TPI RAMJET COMING
hmm I know the pattern is off......what about the offset? I kinda like them....
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Re: http://www.ebay.com/itm/Epsilon-Wheels-/271153370075?hash=item3f220013db&item=271
I think you need hub centric spacers+longer studs with those wheels.Too much positive offset(+25),will hit to tie rod end without spacers.
They are negative offset, just like stock. 25 is right on the money. a (j wheel will fit for sure, the front may need a tiny shim or if you have a brake upgrade the thickness of the rotor (or rotor +1LE hub offset) should do it. For the rear it's perfect. I have ET15 wheels on 1 of mine.
Car: 1991 Z28
well I think they are sharp I'm going to try to get them
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Those would be perfect on a firebird!
I'm sure they'll look good on a camaro too.
Drone358
12-10-2015 08:16 PM
bigjay89gta
10-15-2015 08:04 AM
