15x10 6.5 BS Street Lites? Issues?
Car: 1985 Iroc-Z Camaro.
Engine: Forged 383.
Transmission: TH350 with a Hughes 3500 stall.
Axle/Gears: Moser axles and a Richmond 4.10.
I have an 85 IROC that I'm about to buy wheels for. I'm buying the Billet Specialties Street Lites. There isn't a 15x9 so I can either buy a 15x8 or 15x10. Could I run a 15x10 with like a 6.5 back spacing? I've seen people do it, I was just wondering if you had to do any modifications whatsoever. Post some pictures if anyone has used this setup. I'm running a 275/60 DR.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: 15x10 6.5 BS Street Lites? Issues?
some guys would have you think you could do all the work with just a hammer...(not true) unless you run a small tire!
this is a 10x15 w/6.5 back space.
took more then a days work..
Engine: Forged 383.
what size tire is that?
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
15x10 with 5.5" backspace. 28x12.5" et street very little BFH required running 275 Hoosiers now.
Car: 1985 firebird
Sorry forgot pic here it is
with my set up. you can run the drag radial in the 325x50x15 or the 315x50x15.
or you can run the smaller 275 size also,if your into that class size racing.
but if you want the big sticky tire,tucked under your car. then start cutting!
Street Lethal
04-30-2019 12:14 PM
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
