C6 wheels on my front.
Car: 86 IRoc
Engine: 383 @ 505hp 530ft/lb torque
Transmission: TH350
Axle/Gears: 10 Bolt and 2.73
So, before ordering anything, I decided to try it my self. Due to the fact that no one ever has the same damned answer on forums ever. (Some say 2'' spacers others say 1.5'') This is how far off they are on my front. Pretty sure the 2'' is going to be the ones to get. Anyone have any imput?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: C6 wheels on my front.
Like I tell everybody else. Get the wheels, fit them and see what you need. Every persons preference is different as far as tucked or not.
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
yea have to agree just stick them and measure it its redundant but to get the look you want its neccesary everybody running different brake setups and like more or less tucking so thats why theres a range of different people running different size spacers
Car: 86 IRoc
Transmission: TH350
What do you mean preference? The damn center sticks thru the wheel 1.5 inches. There is no preference there, you NEED 2'' spacers or it wont clear.
Engine: 305 to 350
Axle/Gears: 10 Bolt
you missed the point
he was talking about how much you want the wheel to tuck in or stick out
theres a pic to reference a wheel thats not tuck and a wheel that is tuck would be the opposite
there is a corvette wheel thread that you can take a look at when searching
Im pretty sure the wheel will fit the car with a 1.5" spacer, without the center cap
FWIW, some people use 2.25 spacers in the front with those wheels, or you coudl use 1.75. Or think outside the box and have the hub opening of the wheel opened up a tad so the spindle snout fits through it? You could use a smaller spacer then if you needed too.
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
I have 17x8.5" vette wheels with a 245 in the front and a 2" spacer. It clears but Id like it to sit slightly more flush in the front. Probably going to order a set of 2.25" spacers for the front
The rears are perfect with a 2" spacer 18x9.5 w/ 275's.
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea the front is narrow width at only 8.5" so you would need bigger spacer up front to match rear !
Car: 90 RS
Engine: 5.0 TBI
Transmission: Slushbox
2-1/4 is the minimum I would use on a thirdgen up front with c6 wheels and the rear should have 3" to clear properly with a 19x10.5.....
As suggested you should look in the Corvette wheel section and PM someone that has C6 wheels
Engine: 305 to 350
Axle/Gears: 10 Bolt
Use the search function there are many threads on this subject and a corvette wheel thread
Need about 2in spacer depending on your setup they bolt on there better known as wheel adapter so you don't need longer studs only if your running less than .5" slip on spacer bolt on wheel adapter you don't need longer studs you use stock
