C6 Wheels on 86 IRoc w/ 97 Firehawk rear.
Old 08-25-2012 | 04:32 PM
86InfidelIrocZ's Avatar
Car: 86 IRoc
Engine: 383 @ 505hp 530ft/lb torque
Transmission: TH350
Axle/Gears: 10 Bolt and 2.73
Okay before someone gets all crazy with the "learn to search", I looked into all this before attempting this.
As stated I have an 86 IRoc that I put a 4th gen firehawk 10 bolt under the rear. I have C6 rims and tires that I got from a friend. Everywhere I found said it should be a direct bolt on. The problem is that on the drivers side the tire rubs in the wheel well on the inside sidewall of the tire. After some looking I found that some 4th gen rears were slightly more narrow? I assume my only fix would be wheel spacers. Should I get a wheel spacer and buy bigger studs, or get one of the wheel spacers that bolt on and use new studs? Anyone suggest a good brand? Anyone else have this problem, or use wheel spacers with C6 rims and know which set will for sure clear the rim? Thanks in advance for the help.
Old 08-25-2012 | 04:54 PM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
Re: C6 Wheels on 86 IRoc w/ 97 Firehawk rear.
Where did you find info about some 4th gen rears being more narrow ???
I only have (4) 4th gen rears for reference, BUT they are all the same width
I would guess that you are going to have to go with bolt on spacers (much better option than LONG studs and slip on spacers)
http://wheeladapters.us/
~DaVe
Old 08-25-2012 | 05:04 PM
Car: 86 IRoc
Transmission: TH350
I had read somewhere that the 4th gen firehawk's rear end was 2 inches narrower then other 4th gens. I have not measured it yet. The rear seemed normal. (My stock tires stick out just as much as any of the pics I have seen) Also thanks a ton for the link. The adapters I had my eye on (summit) were $188.
Old 09-18-2012 | 11:27 AM
Car: 86 IRoc
Transmission: TH350
Ok, so I got spacers for the rear. Those fit nice. Now I'm wondering, what size spacers do people use on the front? Some places I see 1.25 others say 2.
Old 09-18-2012 | 12:24 PM
87350IROC's Avatar
Car: 87' IROC
Why don't you just slap them on and see what works best for you? Or take a ruler and measure it.
Old 09-24-2012 | 01:15 PM
browncamaroz28's Avatar
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
I have a pair of wheel spacers for sale that I used for my 96' SS wheels, i believe they were 2" but i can double check and get pictures if your interested. $100 shipped
Old 09-30-2012 | 01:15 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
~DaVe
IIRC, an LS1 rear end is like 3/8" wider total than an LT1 due to the difference in brakes, more specifically the parking brake. So, while not really an issue as a practical matter, the OP is technically correct. An adjustable pan hard might also be of value. I think the problem is OEM and most repop 19" rear wheels have HUGE backspacing so the "normal" guidelines might not apply.
Linson
09-25-2021 08:55 PM
BrianChevy
Wheels and Tires
08-08-2019 03:16 PM
LT1Formula
11-16-2015 02:13 PM
dbrochard
Wheels and Tires
09-25-2015 06:40 PM
buckshot63
09-10-2015 10:15 AM
