I need longer studs
Car: 1992 Camaro Z28
Engine: 5.7L TPI
Transmission: 5 speed
Axle/Gears: 3.47
I need longer studs
I have a 4th gen rear off a 97'. Trying to install some vette wheels but the studs are too short and I'm rubbing this part that sticks out on the inner well. So not sure if I should get spacers or try to bang out the part that sticks out. So I need to get new studs and replace the old ones. How long are the stock ones and how long should I get for the new ones?
Engine: 5.7L TPI
Axle/Gears: 3.47
Re: I need longer studs
I'm not familiar with knurl diameter either. So I'm not sure which ones to order. If anyone can help the sooner the better. Thanks
Engine: 5.7L TPI
Axle/Gears: 3.47
Ok so I can only find a 12.80mm Knurl the stud is 12mmx1.50 RH overall length is 54mm compared to the stock 41.5mm studs. Will the 12.80 fit in the 12.73mm knurl size?
Engine: 5.7L TPI
Axle/Gears: 3.47
Thanks, I went and ordered the slightly larger knurl
1 Post
Car: 91 Camaro RS
Engine: 6.0 lq9 ls bored to 408
Transmission: T56 6 speed
Axle/Gears: strange s60 4.10 with a spool
a trick to help them in is to freeze the studs. shrinks them and then they go into the hub easier.
Pac J
05-17-2020 10:44 AM
