dose anyone like these wheels
1986BANDIT (11-22-2019)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
Re: dose anyone like these wheels
looks alright, im not a big fan of the 9+ spoked rims, these are more like it:
imagine these, 18's on the front and 20's on the back..
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
well to let you know, i am 18, and i do have a lot of money because i am a milker
so... explains that. haha. but like i said, his arent bad either, i just dont like the spoke rims look on camaros, on firebirds either only the OEM
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
COTM Editor
The OP wheel choice looks pretty good. Gives the look of a much more exspensive wheel in what is probably a cast wheel. Do it!
The Black and Machines Helo wheels need to be on a Charger or 300...
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I much prefer the OP selection. The one GreenCamaro posted looks very "wanna-be" and "poser" to my eye. But that's just me.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I'm not a huge fan of replica wheels, if you can swing it, get some real BBS LM's. With that said, if you're not trying to play them off as real then run whatever you like. Are those Varrstoen's even a 3 piece wheel?
COTM Editor (Retired)
i dont like Green's rims. they look "rice" to me. i like th OP's. but either way, wouldnt you need to use spacers?
Car: 1980 Regal
Engine: 383 Superram
Axle/Gears: 12 bolt w/ 3.31 posi
I personally like the OP's wheels better of the two, but they won't work on our cars without bolt pattern adapters. Really wish GM had used the 5x120 pattern instead. Better choices in my opinion.
Varrstoen's are one piece cast. Where did you find a retailer for them, kcaalarcon? I had trouble finding one that stocked the sizes that I wanted. I was planning on putting BBS center caps on them too. Oh noes!
Here's a similar looking wheel to give you and idea of how it would look.
![Name: 5590688271_405e3eba42_b.jpg
Size: 132.7 KB](https://www.thirdgen.org/forums/attachments/wheels-tires/369884d1501379555-dose-anyone-like-these-5590688271_405e3eba42_b.jpg)
to everyone that prefers the bbs, i would get them but i cant afford them and even if i could im not willing to drop that much money into a set of wheels
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Real BBS LM's are over $4,500 just for the wheels. Those are a nice reproduction, what's the price on them?
Transmission: a really good one.
green camaro. those look like somthing you would put on a 2012 mustang. and the first set of wheels looks like somthing would go on a bmw e30 BSS wheels. i love e30 bmws and thos wheels just not on a 3gen. and green camaro im also eightteen with to much money and those wheels are nice just not on a 3gen.
Engine: gone
Transmission: gone
Axle/Gears: gone
I really don't care for either. bigger rims means bigger brakes which means more money so ill just stick with my beautiful stock rims
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
OO those are some nice ones, i do dig those ^
what kind and cost on those?
1 Post
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
![](http://img822.imageshack.us/img822/5122/p5160832t.jpg)
Here's my end result with 18" BMW rims. They're M-Parallels off a 740. 18x8" w/13mm ET front, 18x9.5" w/ 25mm ET rear. I'm running factory 1LE hubs up front (equivalent to a 3/8" spacer), and a 10mm spacer rear. Rubber is 245/40/18 front, 275/40/18 rear. It's sitting on Hotchkis springs. Brakes are C5 HD front (13" rotor) and PBR rear (11.7" rotor). Absolutely no rubbing anywhere, even on full lock.
On a final note, I agree with 90% of the other opinions on here concerning Green's wheel selection taste. Those things look horrendous, and have absolutely no business on any 3rd gen I've ever seen.
-cal30sniper
drptop70ss
10-04-2015 09:44 PM
