Can I run 2012 equinox rims on my 92'?
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: Rebuilt ws6 posi disc rear
delete
delete
1 Post
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
Re: Can I run 2012 equinox rims on my 92'?
I think the bolt pattern is bigger on the equinox, so they won't fit.
Those are a FWD offset wheel, which would require spacers. Because of that, you could have custom spacers made to adapt the proper lug nut pattern if it was required. Unfortunately, whatever bargain you get on the wheels would probably be offset by the new spacers, so unless it's because you really like the look I'd say it's not feasible.
