Velocity wheels or TSW???
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
Need everyones help on this. i finally found a nice set of rims for my bird after the discontinued my torqlites that i wanted....
first was velocity VW855a. i believe the only 18's they come in are 18x7.5... not a problem for me as i dont care much for the wide stance since i dont have the power to compensate for the tire size xP
i do not know if they come in our lug pattern since the sites ive visited dont come with the lug pattern specs. so i dont know if theyre 5x120, or 110 or whatever sizes they come in.
i looked for a site but nothing as my computers retarded.
the next set if i cant get the above rims are TSW Cadwell
ill probably get 18's x8 for the front with the 1.5 in lip and some 19's x 9.5 in the back with the 3 inch lip.
does anyone know if id have problems with either one? also if they could point me out to more info on the velocity wheels thatd be awesome.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Velocity wheels or TSW???
You need to find the offset and bolt pattern for both wheels, you will most likely need a bolt on. Adapter for either of them since I'm sure they are a modern fitment and will have too much offset to fit directly on a 3rd gen
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
As 86TA stated, you will need adapters (2 pairs).
The bolt pattern you want is 5x120. It is a BMW bolt pattern that will fit on our cars. Just be gentle when mounting.
Engine: 2.8L V6
Alright. so find out either bolt patterns and if they dont make any i just get adaptors to make them fit. also find the backspacing right?... how much does a set of those run?
Car: 89 IROC
Spacers will help with the backspacing not the bolt pattern. You need a rim that comes in 5x120 or 5x120.6.
The width of the spacer you buy will depend on the amount of backspacing you want to offset/alter.
drptop70ss
10-04-2015 09:44 PM
