can i run these with a 2" spacer?
Car: 1992 RS
Engine: ZZ4
http://www.ebay.com/itm/18x8-Boss-33...item35ac14fefc
it says the offset is only 2? thought i was looking for a 56mm offset? im running stock rear, will be lowered on sportlines/ tokico hps want to run this wheel with a 255/40/18 will these wheels work or do i have to find another set with diffrent offsets?
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: can i run these with a 2" spacer?
You won't need spacers at all to run those wheels.
EDIT: I said that based on +2mm & the 4.517" bs of a 8" wide wheel, but those measurements don't match.
A 9" wheel with 0 offset is 4.5" bs.
A 8" wheel with 0 offset is 4" bs.
2mm=0.0787" so add that to the 8" wheel #s above & you get 4.0787"bs. It would still fit but makes me question their 4.517"bs.
If there was a typo & it is 20mm, that would make it a 4.787"bs. Still fits but why don't their #s add up to start with? Makes me question all their #s. Is it even a GM fit wheel & not a Ford fit?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
So a 8" wheel with 0 offset has 4.5" of BS, and for that matter 4.5" to the face of the wheel as well. A 9" wheel with 0 offset has 5" of BS because its 10" wide overall.
If the wheels the OP listed are 18x8 with 2m offset, they will bolt right up with no spacers.
Car: GTA
OK.....Somehow I screwed up my #s & I guess my 9" wheels fit without any spacers & have 5" bs? So those will fit.
Car: GTA
My 17" x 11" fit in the rear too without any spacers, although they did require a "little" inner sheetmetal cutting & BFH work.
kah992
08-19-2015 02:55 PM
