lug nut question
1 Post
Car: 1992 Camaro RS
Engine: L98 5.7 350
lug nut question
I have some c5 z06 wheels in 17x9.5 on order and should be here in the next couple of weeks. My question is for those who have closed end lug nuts on their set-up with spacers behind the wheel.
Did you guys need to run an extended lug to fit on the spacer studs when you mounted the wheels? I bought some real $$$-y lugs with closed ends..I would've bought some extended lugs with open ends but due to availability my only option was the standard closed end ones. So if anyone can shine some light on this for me I'd much appreciate it, I don't want to be stuck with these lugs if I open the box and they don't work with my setup.
If it means anything, my wheel spacers are two 2.25" spacers and two 2" spacers.
Thanks!
Thanks!
1 Post
Car: 1992 Camaro RS
Engine: L98 5.7 350
Re: lug nut question
OK since I have all these views and still no answers maybe you all can answer another question for me..
Do Z06 wheels use washers that go behind the lug?
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
what u mean washer like toyota and jags than no where do u get longer studs from
1992rs/ss
16
01-28-2016 09:58 PM
Omega
10-01-2015 02:20 PM
