15x10 with 275/60r15 any issues?
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Anyone have this combo on the rear and if so what issues do you have if any? Also what would be the proper backspace for this combo? I'm looking into Hoosier drag radials and would like to go to the 15x10 on the rear instead of 15x8.
Car: 1985 Z28
Re: 15x10 with 275/60r15 any issues?
You got a sideshot of that setup?
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
How much cutting of the inner wheel well did you do? I have 7" bs & had to do quite a bit of hammering, cutting off portions of the front lower section of metal & a good deal of BFH work. I really don't see how the .5" difference could possibly have caused so much work for my setup compared to yours.
the 5.5" backspacing sticks it out too far. some people are OK with it, but i don't care for it.
mods: cut bumpstop "hump" out, heavy BFH down front. i'm now running a 28x10.5S and it was pretty close down around the front lca mount area, so i took a sawzall to that area. one of these days i'll pull the wheel off and get some good pics.
Car: 1985 Z28
with a 5.5'' backspace you don't have to make those mods though right?
The car is staying at stock height.
1 Post
Car: 1989 IROC-Z28 Camaro
Engine: 403 LSX
Transmission: TH400
Axle/Gears: Moser 9" 3.25's
^LOL I run a 15x8 with 5.5" back spacing 275 60 15 ET street. I have a 9" that's from an LT1 car though...
