New GTO rims
Car: '86 T/A
Engine: Vortec 406sbc-carbed
Transmission: 700r4-vette servo/B&M shift kit.
Axle/Gears: Ready to splode
New GTO rims
I have the chance to buy a set of RallyIII's (new GTO wheels) with tires for $300. They're the same bolt pattern as our cars, but I just wanted to see if anyone else here has done this or knows that they'll work right. They'll be going on my '86 T/A. If anyone can share pictures of this setup it would be cool too. Thanks
Car: '86 T/A
Re: New GTO rims
Well I got the wheels. Great shape with new BFG Gforce ta tires. I went to put them on the car and forgot about how far out our bearing housings sit :'( any one know of an alternative hub or whatever that would allow these wheels to fit?
Car: 1989 Camaro RS
Engine: mild built vortec 350
Axle/Gears: Stock
Re: New GTO rims
How close are they to fitting? If they are close you could use a dremmel with a drum sander to make the hole a bit bigger. Post some pics as I have no idea what the gto rims look like.
Car: '86 T/A
Re: New GTO rims
here's one with the rims sitting by the car, and one with the stock rims next to the rally3's
Car: '86 T/A
Re: New GTO rims
Not close enough for that. and I don't want to do any damage to the new rims so I can sell them if they don't fit. I'm thinking I just need to find a different wheel bearing assembly, if that's even possible.
Car: 86 sport coupe
Engine: 355
Transmission: 5speed
Axle/Gears: 3.73 detroit locker
Re: New GTO rims
Those GTO rims have 5x120mm bolt pattern. Our cars have 5x120.65mm or 4.75". Only .65mm difference, not enough to matter. That is like the thickness of 2-3 sheets of paper. I am using wheels with the 5x120mm pattern that came off a BMW with 1.25" adapters. They will bolt right on with the correct adapter to make up the difference in backspacing. Look at the 17" giovanna thread to see proof.
Car: '86 T/A
Re: New GTO rims
Car: 86 sport coupe
Engine: 355
Re: New GTO rims
ebay is where I got mine. I ordered 4 http://motors.shop.ebay.com/i.html?_...dapters&_sacat=
Put a straight edge across the back edge of your wheel from one side to the other. Then measure down to the back of the center where it bolts to your hub. That is your backspaceing. Do the same to the GTO wheel. Subtract the difference and get wheel adapters close to that measurement.
Car: 86 sport coupe
Engine: 355
Re: New GTO rims
Stock camaro rims have 4.25 backspace. My giovannas have about 5 5/8" backspace thats why I went with 1.25 adapters so they set close to stock in the wheel wells. Go to big on the adapters and your tires will rub on the fender lip.
Car: '86 T/A
Re: New GTO rims
I just started a new job so I haven't actually had time to work on it yet :/ As soon as I get the parts ordered and installed, I'll be sure to post pics
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
