who's running 4 front GTA wheels
#54
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: who's running 4 front GTA wheels
I will have to try to put fronts on the rear again, that looks much better then I remember!
#55
Car: 91 GTA
Axle/Gears: 3:73
[QUOTE=karl's-92'-z28;5602043]T/A Time where did you get the CAI from?[/
It's a custom homemade one. The Crome one is off eBay... The rest is a 3" piece welded and painted. Filter sits in the front fender.
#56
Car: 91 GTA
Axle/Gears: 3:73
#58
Car: 91 GTA
Axle/Gears: 3:73
The suspension is nothing over the top. Just a budget street car.
Frame connectors
Umi wonder bar
Koni yellows (front @ 0 rear @ 1)
Eibach pro kit (approx 1" drop)
Umi single adj. panhard bar
Umi lcarb
Tubular rear lower control arms
Everything else is new moog stuff.
Sway bars are stock ws6 stuff with new bushings.
#59
Car: 85 Trans Am
Axle/Gears: 342
Mine are installed correctly but I'm thinking of rotating them for a more beefy look on the rear.
#60
Car: 1990 FireBird Formula 350
Engine: 360 sbc LT1 aluminum heads & Intake
Transmission: Full manual 700r4 3000 converter
Axle/Gears: gm 7.5" torsen unit 4.10 gears
Good evening all!
I have a 1990 Formula and i've been wanting to do the reversed move for some time now. Started yesterday and i am up to a 5/16" spacer and still full contact with tie rod!!
What am i missing!? I bough the longer studs 610-323 and plan on continue adding until no contact. What is the limit on the oem hub ? Would i have any issues ? please help !
![huh](https://www.thirdgen.org/forums/images/smilies/huh.gif)
![help](https://www.thirdgen.org/forums/images/smilies/help.gif)
#61
1 Post
Car: 91 Trans am
I just had to add a new pic of my car, found a pair of extra front wheels and had them restored, looks perfect ![Embarrassment](https://www.thirdgen.org/forums/images/smilies/redface.gif)
![](https://www.thirdgen.org/forums/attachments/wheels-tires/272507d1393117584-whos-running-4-front-4-fronts.jpg)
#62
Car: 1987 Transam
Engine: LT1 conversion
Transmission: Rebuilt 700r4 w/2400 stall
Axle/Gears: 373
Hey TPI what size tires are you running all around?
#63
Car: 91 GTA
Axle/Gears: 3:73
