4th gen ws6 wheels
1 Post
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
4th gen ws6 wheels
What adapters do I need to make these work, and where do I get them from? I was reading like 1.7" in the front and 2" in the back? Thanks! They are the 4th gen 5 spoke 17x9" wheels.
Car: 88 SC, 89 Silvy, 13 Cruze
Engine: LO3, LO5, LUW
Transmission: 700R4, 700R4, M40-6
Axle/Gears: 2.73, 2.73, 3.94
Re: 4th gen ws6 wheels
2 Inch all the way around. E-bay would be a good bet. I have a set of 16x8s off a 2k Camaro and the 2 in spacers are about 70 bucks a pair.
Car: 91 TA WS6
Transmission: Auto :(
Like so?
This is 2" all around. I can tell you that I need a front end rebuild, the larger tires pull the front end around. The fronts do rub a bit at full lock. The tires are 275/40R17.
Omega
10-01-2015 02:20 PM
