New REV wheels just got here!!! 17x9's American Racing Licensed
#51
Car: 92 Camaro Z28 Heritage Edition
Engine: 350 5.7 TPI
Re: New REV wheels just got here!!! 17x9's American Racing Licensed
#53
Car: '85 Z28
The wheels look good. Wow you live in a beautiful spot!
#54
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
no rubbing.. and im lowered 2".. i got them from "JDwheels" dot com
yeah i live in a rather "swank" part of town.. lots of Dr.'s and company owners.. hence BMW's and various other highend cars abound.. they find my choice in cruiser, "tasteless"... ahahaha my wife tells everyone that its just a project for someone else that im fixing.. ahahaha.. its awesome
#57
"I weighed them as well. come in at 22.5lbs, not too bad if you ask me."
I could understand if it were 10 posts down or something, but this was in the very first post in the thread...And to a more on topic note that seems kind of heavy for 17x9s...
#58
I made a mistake. It happens.
#59
Engine: 4.3 Turbo
Transmission: 4L60
heavy?? for 17x9??? not really.. check around.. my original camaro SS 4thgen wheels were 24lbs..
#60
Don't the cast aluminum factory 16x8 IROC-Zs only weigh around 16 or 17 lbs if I recall though?
#61
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
The crosslace are that light, the Camaro 16" wheels are a bit heavier.
Formula wheel with 245/50/16 tire 50lbs
GTA wheel with 245/50/16 tire 44lbs
15x9 Draglite XP with 275/50/15 Hoosier Quicktime 41lbs
Formula wheel with bald 225/50/16 tire 40lbs
Steel spare tire/jack combo 35lbs
16x8 Formula wheel 25lbs
15x3.5 Draglite with 165r15 25lbs
15" x 9" Draglite XP 22lbs
15x9 Draglite XP w/ 5.5" BS 22lbs
Keystone? 18x10.5 22lbs
17x9 10-spoke SS wheels 21.5lbs
Front Stock 16x8 '91/92 Camaro wheel 21.5lbs
AFS 18x9.5 20.5lbs
ROH Snyper 17x9, 4.5" BS 20.5lbs
OEM GM Z06 by Speedline18x10.5 19.5lbs
16x8 salad shooters 19.5lbs
Rear Stock 16x8 '91/92 Camaro wheel 17.14lbs
165r15 tire 17lbs
Stock Sway Bar (Front or Rear?) 16lbs 6oz
16x8 GTA wheel 16.5lbs
36mm sway bar with brackets/bushings 15lbs
15x8 Draglite w/ 5.5" BS 15lbs
PR Racing A-arms 12lbs/pair
Moroso DS2 26x4.5x16 12lbs
Coil overs 11lbs/pair
Stock torque arm 10lbs
Stock LCAs 10lbs/pair
Pro-fab tubular poly/poly LCAs 8lbs/pair
15" x 3.5" Weld Draglite 8lbs
Aluminum front brake calipers 8lbs
Ground Control Weight Jack rear adjuster, no spring 1lb/pr
AFS 18x9.5 20.5lbs
165r15 tire 17lbs
#62
Car: 86 sport coupe
Engine: 355
Transmission: 5speed
Axle/Gears: 3.73 detroit locker
do they rub at all front or rear?
#64
Engine: 4.3 Turbo
Transmission: 4L60
Updates for what?
No rubbing
No rubbing
#65
1 Post
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
That's basically what I was looking for.
The fact that you did not have to run any spacers is amazing to me - which is why I asked.
Do you feel like you could run the 17x9s up front as well and be ok with space?
#66
Car: GTA
I've run the 17x9/4.5" bs direct fit ROH Snypers for about 3 yrs now with zero problems.
#68
Would 275/40/17 fit the front too. I like your wheels and was going to place an order. Since your wheels are the same, could you try your rears on the front and let us know. Thanks in advance.
#69
Car: GTA
Yes. Pretty much EVERYTHING 3rd gen running a 4th gen wheel doe it since it is the stock 4th gen size tire. And many 3rd gen running aftermarket 17x9s have that size tire too, like me. No problems.
#71
Car: 1986 Z28
Engine: ZZ3
First time I've seen this thread and thsoe wheels look great. I hope the quality lasts for only $139.00 a wheel. I think most 3rd gens need a colored wheel rather than an all chrome wheel since all chrome is a tad too blingy for my taste. Any ways, great look.
#72
Engine: 4.3 Turbo
Transmission: 4L60
275/40/17 will fit without any issues.. i just happend to have the 255's already so i used them up front
#73
Car: 1986 Z28
Engine: ZZ3
According to every fitment sheet I've seen, a 17 x 8 will fit with no problems. So a 18 x 8 or a 17 x 9 should even fit. Just measure and use a fitment guide sheet.
Navy8125
08-25-2015 08:25 PM
