What adapter for 17" ZR1 wheels?
Car: 1989 Pontiac Formula 350
Engine: 350 tpi
Transmission: 700
I have a set of 17x9.5 ZR1 wheels with the 56mm offset I took off my wife's Corvette. Got the correct 38mm offset for her car with new tires.
My question is what size adapter do I need to put these on my 89 Formula? I have read different thoughts but sounds like I need to buy 2.5" adapters which sounds really big. Only needed 1.25" adapters to run them on her 86 vet and they seemed huge.
Thanks for any info.
Engine: 350 tpi
Transmission: 700
Re: What adapter for 17" ZR1 wheels?
Well II had tried the search already with no clear answer.
people run anywhere from 2.5 to 1.5" spacers, depends on the stance you want, fender clearance you want. Note that these spacers bolt to your stock hub just like the wheel does, then the wheel bolts to the spacer. You should never use a spacer that slides over lug studs that is mroe than 1/4" thick. My dad is going to run the same wheels you are and he will be using 2" spacers in the front and 1.5" in the rear.
Car: 1988 Camaro
Engine: 2.8L
1MeanZ, so you can fit a 17x9.5 with a 1.5" in the back? Which rear end does he have?
