Will 275/60/15's fit rear wells without modification?
I got a 91 Ta and am wanting to put 275/60/15's on the back... I got monroe max air shocks on the rear and I can pump em up to about 2.5 inches of lift...if I did so with the tires on would there be any chance of them rubbing?
Car: 87 GTA
Re: Will 275/60/15's fit rear wells without modification?
Depending in the wheels width & backspacing, they'll fit fine. Otherwise, they'll rub. Depends on the wheels.
I plan on getting 15"x8 cragar super spokes
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Its all about the "back spacing" of the wheel that is going to determine if it will fit "within" the well without either rubbing the inside or outer lip.I did some searching and found at Summit Racing that wheel and it looks as if its only offered in a 3.75 BS and a 4.75 BS. I made the mistake of ordering my rear wheels in a 3.75 BS and have had problems with the 295/50r15s rubbing the outer lip. I say 4.75 BS is the way to go but maybe some of the other guys on this site can verify that is correct.Here's a link to Summit Racing =
http://www.summitracing.com/parts/CRR-3305834P/
I'm also looking in to buy summit wheels and would like to know the bs for the wheels. If some one could help that'll be great.
I'm in the market for 15x9 to fit a 275 tire on. Backspacing: ?
1 Post
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
cant remember but i think its in the sticky's at the top of the wheel/tire section
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
15x9 wheel with a 5.5" back spacing on a 275/60/15 here. No rub.
maroe624
04-16-2017 08:29 AM
