Spacer for 18x10.5 / 7.95 bs ????? Please help
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
I was wondering what size of spacers I would need so this tire will be right under the wheel weld or next to the end!! It's 18x10.5 rims with 7.95 backspace and I'm going to have 295/35/18 tires.. Please help me and I don't want to do much hammering or bending???? Please help all 3rdgen also if you have any 3rdgen with black z06 c6 rims please post thanks!
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Spacer for 18x10.5 / 7.95 bs ????? Please help
.95 will keep the wheel just inside the well, .5 more will be about flush or maybe a hair outside the well. You will have to do some clearencing to the inside of the well with the .95 spacer, not as much with the 1.45. Are you sure the BS is right? it seems a little low.
you will DEFIANTLY need a adjustable panhard bar because if the rear is not perfectly square in the car, one side will rub or require more clearancing.
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
No the backspace on the rear is 7.95"?? This is the setup 18x10.5 with 7.95 backspace with a 295/35/18 tire and front are 17x9.5 with a 7.45" backspace and with 265/40/17 tire!
