3rd gen camaro with 5th gen wheels - pics
#303
Car: 91 Camaro RS
Engine: 383ci, Holley 750cfm carb
Re: 3rd gen camaro with 5th gen wheels - pics
I guess I should not have said it was exactly the same, But if you guys are worried about 3/100ths of an inch difference, you should probably throw every wheel you own in the trash because I can pretty much guarantee that unless you own an $8000 set of custom wheels the ones you drive on every day are not manufactured within that tight of a tolerance.
#304
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
I doubt that
That's with correct bolt pattern
your spending money on wheel adapters why not get the correct bolt pattern also or correct the bolt pattern
its a 50/50 chance most people wont have issues others will have issue ..i don't want to take that risk... that's just my opinion ..why not do it right ..but it will weaking your studs
keep in mind you lug nuts aren't properly seated
fyi most high end wheels come from china
Not trying to start anything but just stating facts so other members know the, and not have bad information
#305
Car: 91 Camaro RS
Any part can fail at any time. I don't seem to have any problems with mine And I have the "wrong" bolt pattern. By the way I'm at around 400hp at the crank.
https://www.facebook.com/photo.php?v...type=2&theater
#306
Engine: 305 to 350
Axle/Gears: 10 Bolt
Like I said its 50/50 some have issues others don't ..and yes all parts fail eventually but anything i can do too increase the longevity is a plus..
but good for you
but good for you
#307
Car: 87' IROC
I HIGHLY doubt any wheel out there is a whole 0.03" off. I would expect anything out there to be within 0.005". 0.01" is general machining tolerance. I have never seen a cnc machined part to be off more than 0.01"
#308
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
I dropped serious coin on a set of proper adapters after a few thousand miles on cheapo eBay ones. Never had an issue before but now my adapters are hub centric to the car and lug centric to the wheels. Can't get them any safer than that. Costs about $180 a pair though. Honestly I only did it because I need an exact size adapter to keep my wheels tucked yet clear my brembos or I wouldn't have bothered. As someone who has had this wheel swap since almost day one I have to say a regular set of adapters 2" wide torque correctly have no issues, just check them regularly to be safe.
And my car now has an est. 425+ rwhp and multiple hard launches off a 3200 stall a d plenty of donuts and burn outs....not even one lug snapped....just saying people.
#309
Car: 91 Camaro RS
Engine: 3.1
Ok i ordered 1.75 inch adapters for the front and 1 inch for the back from cj bargains on ebay. These should work.
#314
#315
#316
1 Post
Car: Too many cars
Elcamaro...so the front chin spoiler bolted up with nk problems or is that homemade also. I like the look of the front nose....
#319
my camaro is an sport coupe 83 it´s a homemade chin spoiler even all body kit was made by me.
#320
#322
Car: Pontiac Firebird
How did you get them not to run ? I can barely turn anywhere lol
#323
Just put on 2012 18" 5th gen wheels with 245/40/18 tires on my 87 LT, I used 1.5"/38mm adapters all the way around, and have very minor rubbing on sharp turns in my passenger side wheel well, I think I damaged that wheel well with a big rock when I was driving down some logging roads a year ago but it seems to be correcting itself slowly everyday I drive it....I might need to get 1.75" spacers for it to be perfect.
https://www.thirdgen.org/forums/atta...r2.800.600.jpg
#325
Car: 85 Camaro
sorry man i never finish the car with those wheels on it. I went a whole new route for 2014 and put the 5th gen wheels on my 4th gen.
Im almost done with the thirdgen and still didnt put ground fxs on just yet lol.
#326
Car: 85 Camaro
oh and i have 4th gen rear end and custom adapters in the front.
The custom adapters go from stock 3rd gen lug pattern to stock 5th gen lug pattern with 14mm studs instead of the 12mm stock 3rd gen stuff. They are a custom 1.37" to make the front wheels sit perfectly inside the wheel wells too.
Cost about $200 for the pair and was WELL WORTH THE EXTRA SAFETY as I had lost all my studs on the NJ parkway in rush hour traffic and the wheel shot down the hwy while I was doing 80 mph in the fast lane....when I had ebay adapters on the car. Apparently the stock studs plud ebay adapters plus heavy 5th gen wheels PLUS someone over tightening the adapters and not properly torquing them down caused them to all to sheer off.
NO MATTER WHAT WHEEL SETUP..USE A TORQUE WRENCH!!!
(coming from a USAF JET ENGINE MECHANIC...ITS IMPORTANT and takes but an extra minute)
#327
Car: 85 Camaro
Heres my car after I painted it, put brembos on it, full tubular suspension including kmember and aarms.
No bumpers ground effects or engine/transmission at this point but it looked AMAZING once everything was on it and it was dropped down just cant find any pictures of the car at that point
#328
thx for the tip: car looks good
#329
Engine: 305 to 350
Axle/Gears: 10 Bolt
looking good jerseyboy
drags look Alot meaner and like it way more than the 20s lol
i have to agree well worth spending extra
ebay wheel adapters use lower quality aluminum , there no warranty and they come from china where regulations are lets just say not as tight.
comaparing adapter that i got from a reputable company vs ebay difference is apparent
but this is a touchy subject for some people
IMO its worth getting quality Adapters and gotten multiple ones from this company with no issues and fits like a glove
#330
Has anyone had problems with the wheels studs? 3rd Gens are 12X1.5 and 5th Gens are 14X1.5. I just bought a set of 19" 5th Gen Wheels and didn't realize the stud size difference. Will/could this be an issue? I have adapters but they have 12X1.5 studs
#331
Car: 85 Camaro
Read my comments just 3 posts above.
BTW the company I used was www.motorsport-tech.com made in USA which I like and product was insanely well made.
#332
Engine: 305 to 350
Axle/Gears: 10 Bolt
They have lifetime warranty also i have couple adapters by them big difference compared to ebay versions
#333
Car: 1991 Camaro RS convert
Engine: 5.0L TBI
Axle/Gears: 4th gen axle/4.11 gears
I just wanted to share my new wheels. They are 18" 5th gen wheels. I only have 3 painted so far. I ran out of paint for the last one.
#336
Engine: 5.0L TBI
Well I got my tires painted and got rubber on them. I have a 4th gen rear and these wheels will not fit over my axle I need like a 1/8 in clearance on the inside of the wheel. I' m looking at 2 options. First I could grind my wheel to make space for the center piece of the axle. Second I could get a 1/2 in spacer and get longer studs which would help the stance. I'm trying to get this done with as little money as possible. I'm already down about $1100 with the wheels and tires. On the front I'll be using a 1 in adapter since I have 4th gen brakes.
#337
Engine: 5.0L TBI
After much work here is my final look(please ignore the dirt). I had to grind the rear wheels to make clearance for flange on the rear axle. There is no spacer on the rear and a 1in adapter on the front with my 4th gen brakes.
#338
Engine: 5.0L TBI
Here's another from the front
#339
Car: 92 Camaro z28
Engine: LQ4 6.0L Vortech w/ aluminum heads
Transmission: 4l60e
Axle/Gears: 3.42s from 99-02 WS6
@ nefarious
those rims look awesome like that. i went with the 2010 5th gen wheels like the one from the original thread starter but i really like what you did with your wheels.
are they staggered?
what size are they?
are they staggered?
what size are they?
#340
Engine: 5.0L TBI
They are 18's all around. I think that they stick out a little more because of the 4th gen rear.
#341
nasty nasty nasty I don't know about anyone else but I think those are hot. I got a set in my barn right now and you just gave one heck of an idea. I hope you don't mind me copying you. I was having thoughts of selling my car or heck idk doing something but now you have re-awakened my interest. I think I will drop in a heater core and take it somewhere to get the carb tuned correctly. thx man!
#343
19 inch 2010 camaro rims. 285 30 19 in the rear and 255 35 19 in the front with 1 inch wheel spacers all around. no rubbing at all
#347
#350
