17x11 17x9 zr1's on a 92 Camaro
What is it going to take to get these to fit? The wheels are 17x9.5 with a 56 mm offset, and the 17x11's have a 50mm offset. Also what size tire should I run? Should I get 2" spacers or larger?
Car: 87 GTA
Re: 17x11 17x9 zr1's on a 92 Camaro
2.25" front, 2" rear.
Or put in a 98-02 rear & you'll get big disc brakes & not need the rear adapters. 93-97 rear will do the same, but you'll have the same size disc brakes. If you have drum brakes now, then both are a win-win option for you.
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
The best tire size for the fronts to not rub is a 275/40/17 and the rears should be 315/35/17 for the best, widest look you can fit under our cars.
Who might make the best wheel spacer since the other shop closed down that everyone recomended. I am pretty close to doing this mod soon too, so good info to share if anyone has it.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1996 Grandsport = 50mm. 1990 - 1995 ZR-1 = 36mm offset
84z96L31vortec
08-20-2017 12:16 AM
