Need Help please...
Car: 1990 camaro rs
Engine: 305 tbi
Need Help please...
hey guys I have some Parnelli Jones Firestone tires and the only numbers I found on it was N50-15 and I measured the tread width and it was 11" across, has anyone used these and what kind of rims do I need and what is the backspacing i need to put these on my camaro without rubbing?
thanks Tim
thanks Tim
Re: Need Help please...
Tire SizeN50-15
Wheel Diameter15 in.
Sidewall StyleBlackwall
Tire ConstructionBias-ply
Directional No
Tire Diameter28.20 in..
Section Width12.80 in.
Tread Width11.00 in.
Minimum Recommended Wheel Width10.00 in.
Maximum Recommended Wheel Width10.00 in
Its gonna rub if you dont cut the wheel well. Need 5.5-6.5 backspacing rim. Your gonna bust your rearend with these also.
Directional No
Car: 1990 camaro rs
Engine: 305 tbi
I dont think they will they tuck under perfectly last time I set them up, and the car will be lifted in the rear anyways with some air shocks
Thats why you cut the wheel well and use a 15x10 with 6.5 backspacing. Thats a whole lot of tire for a 305. Do you plan on upgrading in the near future ?
Car: 1990 camaro rs
Engine: 305 tbi
yepp hopefully everything will be done over this winter, btw why did you say I'm gonna bust my rear?
The plan -
-84 350 vette motor with 383 build
-350 or 400 trans
-4th gen posi rear (mabye) or rebuild on mine
-front end rebuild
-finish up my iroc hood or getting a 3" sunaco
theres more but its too much too list, unless I can get enough to buy a roller everything will go on this car
The plan -
-350 or 400 trans
-front end rebuild
Stock ten bolt 3rd gen or 4th gen break with stock motors and street tires. Putting that much tire under the car and actually hooking will grenade it the first time out.
Car: 1990 camaro rs
Engine: 305 tbi
Im not sure about that, im not dissing what you say I'd just like a second opinion thats all. and if it gets rebuilt it'll have a 4.10 gear and i really dont see that or the posi out of a 4th gen breaking...
What ever floats your boat. Just post back when you throw those slicks on and hook good and break the rear. My rear is buit with all the best stuff and I have 4.10's in it. And I will only run street tires cause I know what will happen if i hook.
Car: 1990 camaro rs
Engine: 305 tbi
They are street tires not slicks...and I've been to the tracks with my car and nobody was worried about me breaking it they just wanted me to have a driveshaft loop
Most tires with the N50-15 PN# are drag tires. Trust me your gonna break your rear with the 383.
