Buddy Club Wheels?
Buddy Club Wheels?
Does anyone know if these would fit directly onto a Camaro? I was thinking about get 17in in the back and 16in in the front.
Also if anyone has pics of their car with these that woulds be great.
Thanks!
http://www.ilovebodykits.com/product...att_Black.html
Thanks!
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Buddy Club Wheels?
that wheel has the wrong bolt pattern. you need 5x120.65, or 5x120 will "work" 7" wide is preyy narrow too. more of a tuner wheel
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Buddy club is a company that promotes its products toward the import crowd. Those wheels are for a honda. 4x100 17x7 +42 offset would be for a 96-00 honda civic. If you like the look of those import or drift style wheels go with volks, or if you want to spend less rotas. You will want something wider that 7''. That 7'' wheel will use a 205mm wide tire which is way small for a third gen. You want 235 and larger. If you are buying after market wheels shoot for 10'' in the back or all around.
you wont be able to find a lot of matches for your car just by searching site under (90 camaro). You have to seearch through wheels by their specs, 5x4.75 bolt pattern, and then the backspacing/offset, which depends on width. FWIW, 8" wheels want 4.5" of BS or 0 offset.
Yeah I saw on here that I should search for 4th gen wheels and get a spacer but I have another question is 10.5 too wide for the back because I found a nice set of corvette wheels on sale and the rears are 10.5 in wide.
no, 10.5 will fit the rear, maybe need a little hammering of a couple places.
84 TA NV
09-06-2015 08:02 PM
