will a 275 fit on 7" rim?
Car: 1989 GTA
I have a couple drag radials in size 275/50/15 will they fit on a 15X7" wheel? Thanks
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: will a 275 fit on 7" rim?
When you look up that size tire on Summit, every tire says to put it on a rim 7.5" to 9.5" wide. So according to Summits site, that wheel is a tad small for that tire. Better off finding some 15x8's.
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
It'll fit. May look funny. Ideal size is 8-9.5" wheel
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
My buddy had a 295/50/15 on a stock 15x7 rim.
It was bulged, and looked funny, but it worked.
275 should work "ok".
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Typically the small wheel will pull the tire in & you will lose tread contact at the outer edges, so traction will be no better than a tire of the appropriate size. If they are free, then OK, if buying a tire, go with something a little smaller.
Street Lethal
04-30-2019 12:14 PM
ambainb
04-25-2016 09:21 PM
Djmathis123
09-29-2015 01:36 AM
