17x10s... will they fit in the front?
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 17x10s... will they fit in the front?
With about 5.25" backspacing they'll clear the suspension, barely, but will stick out a wee bit.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
you still haven't specified a backspacing or offset. You'll need to space them until your effective backspacing is 5.25"
Car: 87 GTA
With the correct adapters, yes.
http://www.skulte.com/adapterfaq.html
Since those specific wheels aren't listed there, you'll just need to figure out what your backspacing/offset is & find a wheel listed that matches yours.
Car: 87 GTA
Yes. Any less & you'll hit the tie rod end.
I have 5" bs & less than 1/4" between my wheel lip & the tie rod. I couldn't even get a 13mm wrench in between them sideways (flat).
ok cool.. but they will fit yes?
should i get more than 2 inch spacers? after doing some math it seems 2 inch spacers are exactly what i need..
Acually i have another question, if i do the ls1 brake conversion, what size spacers would i need then? doesnt this change things a little?
1 Post
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
I dont think they make that big a difference. Maybe a 1/4" if that. You use your stock rotor as the hub, then put an LS1 rotor over that, then your spacer/wheel, so it only pushes it out the thickness of the rotor.
1 Post
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
The LS1 rotor will push things out 0.300" IIRC so you should just go with a spacer that is 0.250" narrower then what you had initially planned.
Street Lethal
04-30-2019 12:14 PM
ambainb
04-25-2016 09:21 PM
