2010 Heritage Steel 18x7.5 fitment?
Wheel the 2010 Camaro LS Heritage Steel 18x7.5 rims fit on third gens? Will the bolts that come with the hub covers fit the studs on a 3rd gen??
Just asking cause i would hate to be stuck with these rims =]
Thanks for any and all help
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: 2010 Heritage Steel 18x7.5 fitment?
the lug size is different, 14mm vs ours which is 12mm, not sure if thats an issue or not, our lug nuts may not be wide enough.
as for the bolt spacing, i "think" they are 5x120, same as bmw ect, which will work, but is a hair off, .65mm to be exact.
backspacing should be about 4.25 to be right, can be a little different, not sure what those wheels have
sounds like you already have them? why not just try to fit them?
and they are 18" steel wheels? those mothers must be heavy
thats a ridiculous amount of unsprung weight your adding, not a good idea
3rdgenparts
05-21-2016 11:50 PM
darwinprice
17
10-11-2015 11:51 PM
skinny z
10-05-2015 06:23 PM
