can i run 46mm offset rims on all four conners with spacers?
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: can i run 46mm offset rims on all four conners with spacers?
sure, but what width? thats important too
8.5"
the rims i want come in a set for a 4thgen camaro/ firebird they are front 18x8.5 with a 46mm offset / and the rears are 19x9.5 56mm offset. i want 18" all around and i don't think 9.5" would fit with out modifications to the wells. so i can order the ones i want individually
well, 9.5 will fit the front with an 18" wheel, its quite common really. However, a narrower wheel and tire upfront wont be as much of a handful on lousy roads.
and the 9.5 will fit the rears without much drama, maybe some hammering in teh front of the well, but probably not.
yea... these will be 18x8.5" on all four
