14x7 Will these fit?
I have an 88 firebird and was wondering if 14x7 Cragar keystones would fit and if not what would it take to make them fit?? This is all I was told about the rims,
had them on his 65 gto since 1976, and had the car frame off restored and put the original rims back on they are just a driver set of old classic type rims the 2 front one have a different offset to the back ones but they are all 14 x 7 rims they need the offset for fit on the a body cars in this era.
thanks
thanks
Car: 87 GTA
Re: Will these fit?
Not sure if a 14" wheel will fit over our brakes. Good luck trying to find someone running 14" wheels. Not impossible, but scarce info.
I recommend adding '14 x 7' to the thread title, to catch peoples eyes & get them to look inside. People can't tell you, if they don't read.
Car: 83 berlinetta
Engine: 305 roller motor
Transmission: th350
Axle/Gears: 10 bolt 3.08
Re: 14x7 Will these fit?
yes they should fit stock berlinetta's came with aluminum 14 inch wheels and and all third gens had the same brakes except rear disc and 1le etc etc as long as they have 4inch back space and 5x4-3/4 bolt pattern you should be good.
also I am currently running 14 inch ultra drags and they fit fine.
alright but if the bolt patterns were different, would there be a way to modify them to make them fit? like with spacers?
Car: 83 berlinetta
Transmission: th350
yes a couple companies make bolt pattern adapters try summit or speedway motors just know those will make the wheels stick out further that may or may not cause a problem with the steering clearence but I dought it.
New2Chevy
09-28-2015 12:35 AM
