Are these wheels stock?
Hello, I am wondering if any one can help identify these wheels. They came on the 1988 trans am i bought a few years ago. but the wheels i see on other trans ams from similar years look alot different. can any one help?
Car: 1991 Camaro Z28
Engine: Carb 5.3
Transmission: Th350
Axle/Gears: Moser 12 bolt, 4.11 gears
Re: Are these wheels stock?
if they are 16X8 they are stock for GTA's. whether thats what came on your car i dont know
They are 16x8 all other gta wheels ive seen have the lacing through out the lug nut area and these are smooth so I wasnt sure if they were original... thanks for your help
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Those aren't stock. They look to be an aftermarket remake/copy of the GTA rim. the GTA rim has the cross lacing all the way around the lug nut cutouts and around the hub, they don't stop and go solid like yours.
no those wheels are not stock. As said above they are a poor reproduction of some sort.
Here is a picture I took of the stock GTA wheel on my 88 GTA. Keep in mind there are two styles of crosslace, this is the 88-92 diamond spoke version.
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
those look like the rims off an late 90s till mid 90s boniville
Car: 1991 Formula 350, 2002 Grand Prix G
Engine: 350 with SLP & Edlebrock mods
Transmission: 4-speed automatic-700 R4
Axle/Gears: 10 bolt with 3:73
What does the OTHER version look like and what is the difference? I have heard it is the small dimple on the bottom of the large spoke. How much fun is it to clean 80 holes X 4 after any car show.
This is the 87 style crosslace wheel. You are correct it does not have the dimples, and the dish has a different finish on it.
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
Believe it or not the wheels in question are acturally O.E for the Jeep Cherokee Country and Limited packages during the 90s up til 1997. they were cheap answers to replace T/a wheels since they have the honeycomb feel to them
Car: '87 Iroc
Engine: 350 .060 over
Axle/Gears: 3.70 9bolt
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
Nope. In your pic the outer most spaces between spokes are solid. In the wheels he has they are open. Similar but no cigar.
1 Post
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
hmmmmmmmmmmmm so where did the mystery wheels come from.. sounds like a fun trivia
Car: 1991 Pontiac Firebird
Engine: 3.1L V6
The wheels in question I believe are either enkei 92s or american racing (A.R.E) replicas. If they are either of those, the brand should be cast into the backside of the wheel.
Car: 1982 Pontiac T/A
Engine: 350 Carb
Transmission: TH200c
These Came on a 1984 T/A I bought last week.. Just thought Id ad to the confusion.
LT1Formula
11-16-2015 01:13 PM
kah992
08-19-2015 02:55 PM
