refinishing rims..
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
Axle/Gears: 3.45 g92
refinishing rims..
I have a 1987 Iroc z.The rims have some dark spots on them and some of the plastic or clear is coming off. Is there a product out there that will strip the clear off so I can sand the wheels then polish them? I'm not sure if thats the correct route but I did something like that to some 1993 grand prix rims and they came out nice.if anyone has refinished there rims themselfs or know how to let me know. I love stock rims just they look bad now.
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: refinishing rims..
correct.
I couldn't find the air craft stripper in town so I just bought some paint stripper made for metals by klean strip at a local hardware store, probably very similar stuff. I tried it last night, it worked great! Brushed it on, 10 minutes later most of the clear coat was peeling up, I wiped that off with a rag and spread some more on and that got most of the rest. Sprayed it off with a pressure washer and was good to go. The metal that had the clear coat on it looked perfect. The spots that had been missing clear coat cleaned up pretty easily wetsanding with 600 grit paper. I'm going to do the rest of the rims this weekend and then polish them with some aluminum polish and see how they look, I kind of like the machining lines in them so I don't want to sand them too much.
Make sure you do it in a well ventilated area, I did it in the garage with the door wide open and my eyes were burning from the fumes when I was spreading it on!
Car: 1984 Berlinetta,'82 and '86 Camaro
Engine: Rebuilt 350
Transmission: Automatic. =[
Axle/Gears: Stock
did you reclear the wheels then? if so, what kind of clear?
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
I would.Dupliacolor makes a clear for rims.Its high temp. I'm gonna try this week to redo one of my rims. I will take before and after and post.I figure the rims look bad now so..why not..
Engine: Rebuilt 350
Axle/Gears: Stock
stripper seems to working very good on my set...please post pictures of recleared wheels. =]
TimOld82Camaro
05-05-2003 10:16 PM
88IROCARMY
03-29-2001 09:28 PM
