3rd gen wheels on C4 corvette?
Old 02-05-2010 | 10:24 PM
derekterbeest's Avatar
Car: 1983 Camaro Z28
Engine: 350 CFI
Transmission: 700R4 automatic
Axle/Gears: 3.08?
can i put 15" Z28 wheels on an '86 C4 vette?
i found a suuuuper cheap vette that doesn't have wheels and tires, but i have an extra set of third gen 15" wheels and tires that i could put on if it would work.
Is this something that will fit?
Old 02-07-2010 | 04:12 PM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Re: 3rd gen wheels on C4 corvette?
Bolt pattern is the same. They should fit.
Old 02-07-2010 | 10:59 PM
vette gator's Avatar
Car: 85 Z28
Caliper clearance would be the main thing I would worry about. If you do it, I'd love to see a picture. I've seen lots of Vette wheels on third gens, but never a third gen wheel on a Vette. I'm curious how it would look. In any event, stock Vette wheels go pretty cheap, so even if your wheels don't fit, it shouldn't cost that much to put a set of wheels on the C4.
Old 02-10-2010 | 08:03 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Vette wheels have a diff offset. They'd stick out and look a litlte funky. The bolt pattern is the same though.
The rear brakes should clear fine, the fronts are questionable.
PurelyPMD
05-05-2016 05:57 PM
the_hamturdler
09-30-2015 01:50 PM
dusterbd
09-29-2015 09:40 AM
dbrochard
Wheels and Tires
09-25-2015 06:40 PM
turbobuick88
Wheels and Tires
09-08-2015 09:27 PM
Quick Reply: 3rd gen wheels on C4 corvette?
