My home made CNC wheel lathe.. For under $40..
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
A while back I saw a post where a guy jacked his car up, to polish his wheels.. Since I found that to be an easy way to die, I took the idea and ran with it.. I built a 2x4 frame table, 3'x3'.. Cut, and modified the end of a 7.5" axle, mostly for the bearing, and used a 17.5 RPM DC motor, with a variable speed control and a forward reverse switch (It was for a press, and we had it in storage.)
This is what I came up with.. It looks rough, but man does it run nice..
I haven't tested it yet with the sander, I'm hoping it works good...
1 Post
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: My home made CNC wheel lathe.. For under $40..
Do you have any videos of it working?
1 Post
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
That's a fun/cool project, but the post subject is WAY misleading! There's nothing CNC about it. That would mean you're machining rims using a computer controlled tool... unfortunately that costs a lot more than $40 :-(
Anyway, how do you have the axle section secured to the wood frame? What kind of sander do you plan on using? What did you use as a coupler from the DC motor shaft to the axle shaft? Are those exposed wire nuts hanging? the wire looks like it's pulling on them. you might want to better secure it so they can't be pulled apart with live wires.
kah992
08-19-2015 02:55 PM
