Cragars?
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Cragars?
Could people post pictures of their camaro with cragars?
something like this, they are a cragar black d widow..
Car: 88 SC, 89 Silvy, 13 Cruze
Engine: LO3, LO5, LUW
Transmission: 700R4, 700R4, M40-6
Axle/Gears: 2.73, 2.73, 3.94
Re: Cragars?
Can you get a picture of them straight on, if so I can put them on my car, or yours if you get me a picture
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Engine: 3.0L 2JZGE
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Cragars?
i think i cam myself a lil... thats freaking sweeet looking, i love the trim on the 91~92, and the high rise with the blisters on the hood, your car is mint man! i have a black 89, it doesn't have a great paint job like yours but im loving the cragars with the car. im really going to like these wheels on mine
curious... can i skin my antenna? i dont use it or need it anymore...
Engine: 3.0L 2JZGE
Re: Cragars?
Tony.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Cragars?
I'm curious, whats the biggest size tire I could get for the rear, well widest i mean, tire not wheel. I want to have a stagger look and grab a bit more traction.. But i kind of want the tires both to look the same size from the side, but from front and back you can tell a big difference
Engine: 3.0L 2JZGE
Re: Cragars?
I checked those wheels out on summit and they come in something like a 4" backspascing in a 15x10. The min. you need with a 15x10 is 5.5 backspacing or they will stick out past the fenders. Whats your rim specs Tony ?
Re: Cragars?
those look sharp, not to TJ but any have ones with the bead lock? i think they look sweet as hell
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Cragars?
Yeah I don't mind my tire sticking out of the lip of the car.. I want a tire that will fill up the whole width of the well, i mean from the side to side without sticking out or rubbing. Just the width, i'm wanting to keep the tires look the same size from the side of the vehicle
Re: Cragars?
Depends on who you ask. Can you fit a 295 on a 15x8 rim yes. Do they bulge something terrible yes. Do you only wear out the middle of the tire cause they bulge so much yes. This can also be said with a 275 tire but it dosent look as bad on the rim.
Engine: 3.0L 2JZGE
Re: Cragars?
It sucks that they only come on a 4 backspace for the 15x10 I wonder how much it would stick out?
Tony.
Car: Camaro RS
Engine: 305 TBI
Transmission: 700
Axle/Gears: Borg-Warner 9 bolt
Re: Cragars?
Try here http://www.rims-n-tires.com/rt_specs.jsp
in the left window input the stock wheel+tire combo and in the right the one you want to fit and it will tell you below how much it will stick out etc.
Engine: 3.0L 2JZGE
Re: Cragars?
Tony.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Cragars?
So the 15x10 would be to much... If i stick with the stock size whats the most I could do? But still not getting the hump in the middle so it doesn't over wear and ruin the tread.
Re: Cragars?
A 15x10 with 6.5 backspacing is perfect but you need some fab skills or BFH to make it fit.
15x8 with the right backspacing and a 265/255 tire will work. You can use a 275 but would probably have to take some air out of the tire and round around 20psi .
15x7 will work with the max of a 255 tire and you will have to also lower the psi to about 20 psi.
Re: Cragars?
If you run a tire thats "too big" for the rim its on its going to bulge. If you run that tire at the recomended tire pressure, usally around 32 psi the tire contact patch will only be in the middle of the tire because its bulgeing so much. If you lower the psi you deflate the tire and "flattening out" the bulge which equals more contact patch.
Engine: 3.0L 2JZGE
1 Post
Car: 87 firebird
Engine: carbed 305
Re: Cragars?
ok, im confused. im set on this wheel 15x8 x4.75 with 4 inch backspace. 50 bucks a piece. i was going to order them from summit tonight but i looked at there shipping info. and it said that for a 200 range purchase it would cost 12 bucks. every where else it seems like shipping is just as much as the wheels themselfs. but i looked more and it said that items that were to heavy had to be hauled by truck and it didnt define "to heavy/to big. has anyone ever bought from here and how did u determine. maybe tomorrow ill call summit.
Engine: 3.0L 2JZGE
Re: Cragars?
Summit is open 24 hour's you could call now and ask them but I know that pepboys carry these wheels too but im not sure what brand they are though.
Tony.
Tony.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Cragars?
This is a 295/50r15 tire on a 15in. by 8in. wheel ( 2 years old at 35 psi. and they are wearing fine. )
Car: Camaro
Re: Cragars?
I bought 15x8's and put 275's on them and they kept rubbing the outer fender over bumps. The backspacing on them was 3.75. I went down to 255's and it still rubbed a little. I'm getting the same wheels again this summer with a bigger backspacing.
#42
Car: 1986 Trans Am
Engine: Carbed 355
Transmission: Th700R4
Axle/Gears: 3.73 Posi
Re: Cragars?
im so confused with what backspacing is. i know the 15x8 will fit on the front as stated but for the 15x10 do i need a spacer or something to make it work, if so what size spacer and what size tire would you reccomend, i do not plan on ever lowering my car either, thanks.
#43
Engine: 3.0L 2JZGE
Re: Cragars?
Tony.
#46
Engine: 3.0L 2JZGE
Re: Cragars?
It will just stick out thats all I dont know how much but yeah.
Tony.
Tony.
#47
Engine: TBI,5.0
Re: Cragars?
My rear wheels and tire stick out some because I have A 295/50r15 on a 3.75 backspaced wheel. If you want to run a fat tire on a 10in. or even a 8in. wheel your going to need allot more backspacing. 5.0 at least in IMO. Maybe some here can help explain better how backspacing works or at least punch in " what is wheel backspacing" on Google and try to figure it out. Hope that helps some.By the way I had to run special shocks to keep my fender flairs from bottoming out.If you get the right backspacing you will not have that problem. Here's a photo of what I mean.
#48
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Re: Cragars?
I'm set on these wheels now, but I'm goin to use my black painted
stocks till this summer. But one thing I noticed is that they make a 15, 16, 17. Stock I have 16's and I know I can put 295/50s on 16x8 and it's fine in the rear. The only thing is idk what rim size to go with. I love the look of 15s on the Camaros with th bigger tires in back. But I also like 17s because I like the amount of rim. But Im also concerns about rubbing up front which makes me want to stick with 16s but that also makes me want to save my money and keep my black stocks and put 295/50 on those. Any input?
#49
Engine: 3.0L 2JZGE
Re: Cragars?
Its up too you really on what type of look you want for your ride. The black ones gives more of a NASCAR look especially if you have tires with the white bold letters looks real dope. I thought about the 17's as well but not sure that would be one heavy rim.
Tony.
Tony.
#50
Axle/Gears: stock
Re: Cragars?
Yah, I was looking at these a last year and then got away from them and started looking for more of a 5 spoke look. But after seeing how thy look on your car i fell in love with them. Lol your car looks so sick with those on there. That's a great point on the 17s I was lookin on summit last night bu couldn't fins how much these weigh. What I'm goin to do for now is weight till after I get it painted to see how the black on my stocks even looks with the two tone colors I'm doin, black on top and atomic orange on the bottom, then go from there. I'll prbly just keep my stocks until after I get the rest of the car finished, interior/rearend. But ik I'm def gunna put some 295s on it while I'm waiting to pick out the rims I really want. I love the price of these, quality made with the cragar name too. But I love how your car looks Tony, it made me want to just paint my car complelty black like what I was gunna do before. Lol
