5Zigen fitment
5Zigen fitment
Which of the size options for this wheel would give me the fewest clearance issues on a third gen, and what sort of adapters and spacers would i need to make them work and where would I get such adapters?
Thanks and sorry for my ignorance... I have no experience with wheel fitment at all.
http://www.5zigenusa.com/english/pro...er/ZR+520.html
Re: 5Zigen fitment
Looks like there all for jap cars. Thats the most retarded fitment chart I have ever seen.
Re: 5Zigen fitment
its hard to read that fitment chart but im guessing no. Just go on summit racing and pick out some rims. There selection chart is much better and post any questions on here after.
Car: 87 GTA
Re: 5Zigen fitment
That chart is as clear as it could possibly be, for a person who understands it....But of all those wheels, only 5 have the correct lug circle & would still require more $ to be spent on spacers.
Do yourself a favor & buy direct fit wheels that fit correctly & do require you to run double the number of lug nuts & spend more $ on spacers.
Go to Tirerack.com to see what it out there. To see more that what they "say" will fit your car. Then look up a 2000 BMW 328i & look for wheels that show the backspacing as less than 5", to fit on all 4 corners. The rear wheels can have a little more, or even more than "just a little" backspacing depending on how much cutting or BFH work you are willing to do.
Car: 87 Formula 350
Engine: 350tpi
Transmission: TH700R4
Axle/Gears: 3.23 limited
Re: 5Zigen fitment
none of those will fit like OEM
but if you like the "hella flush" look (google it), you'll want the Mustang lug pattern, 5 hole 114.3 and you'll need a 1.25" adapter from eBay 4.75 to a 4.50
for reference;
+20 will stick out ~1/2" in the rear 10.5" wide wheel.
+24 roughly ~1/4" in the rear 10.5" wheel
+27 roughtly ~1/4" in the front 9" wheel
with 17" I would go with: front 8" +25/9" +27 rear
18"- 8.5 +25 front/9.5 +20 rear but need a fender roll.
19"- I would go with +20 but need a fender pull all around or wide body kit.
here's mine
http://img148.imageshack.us/g/photo0168.jpg/
FRONT WHEEL SIZE: 17x9 FRONT WHEEL OFFSET: 24mm REAR WHEEL SIZE: 17x10.5 REAR WHEEL OFFSET: 27mm BOLT PATTERN: 5x114.3
for reference;
here's mine
Chad Speier
09-24-2015 12:32 PM
86White_T/A305
09-21-2015 05:28 PM
