My wheel painting project
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
I don't like my wheels... it's not the style, it's the color... it's so BLAH
here's what they look like
I want to paint them black, but leave a shiny silver finish on the flat parts and the rim. I could have bought a set of wheels already black, but the silver part would have had machining ribbing, and I'm going for something with a little more pop than that
First, I bought one extra wheel to experiement on, this way I'm not disabliing my car while I work on one wheel at a time.
This wheel wasn't painted like mine, it appeared to be natural aluminum. First, I took 220 grit paper, and sanded off the machining marks. I then followed it up with 400, 800, and 1500, and finally finished with rouge applied from a dremal tool
this is the result
then I masked off the shiny parts with fine line tape, and regular old green around the rim
I went ahead and primed the whole thing to help the paint stick to the aluminum.
now I'm off to go buy some glossy black wheel paint, and apply at least a couple coats before I pull off the tape. I'm probably going to put a clear coat over the black and the silver, but I'm not sure if the clear will stick to the silver or not. I may have o sand it off later if it winds up being a problem
More updates later
this is the result
More updates later
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Re: My wheel painting project
That should look good, post some pics when ur done.
two down, two to go.
It's odd, the wheels that came on the car (the ones that were painted) seem seem to be a different alloy than the one that was bare aluminum. It doesn't shine up nearly as well, and the casting marks and ribbing are not nearly as pronounced, but the alloy seem MUCH harder. I have to work twice as hard to get out ribbing half as large. Anybody ever heard of this?
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
That looks real good!! Now you got me wanting to get that style & paint 'em to match the body color!! GREAT JOB!!
Car: 91 Camaro Z28
Engine: 5.0L LB9 305 TPI
Transmission: 5 spd
Axle/Gears: 3.42 Rear End
That looks really good, Im trying to find time to paint mine for now im rolling on pink Z28 wheels, lol.
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
I got 2 out of my 4 done before a set of 91/92 rims basically fell into my lap, so I have to start all over again.
Little tip though, when you have the wheels balanced, put tape weights on the inside or static balance them, keeps the weights from scratching up your rim.
Car: 1992 RS
Engine: 305 TBI
Transmission: Stock Automatic
Axle/Gears: Stock
yeah dude those will look nice. Its amazing what a little time and personal effort can get ya! I am in the middle of painting a set of 91-92's for mine. Here is my first one i finished. These, a set of BFG G-Force's and a nice 1" to 2" drop and this portion of the project will be done..lol.
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
they look great man for sure. Couldnt tell you the difference in the rims tho. I did mine as well at the beginning of the year. this is what they cam out like as well
done! All four wheels and tires are on the ground. I'll take pictures at the NTTGA meet on saturday
Car: 89 IROC
Man it must be nice to drive your 3rd gen all year round as mine is stuck where I store it with a foot and a half of snow blocking the door. Oh well its mod time LOL
Transmission: World Class T-5
Axle/Gears: BW 3.45
Car: 89 IROC
Its a aluminium flake grey colour and with the flash of my camera they look completely painted but I only did inside the spokes and the single line stripes. This is what they look like on the car. Sorry about the pics as they are the only two i got that really show the rims. Didnt get to drive the car much this year so I didnt get really any nice pics
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
that looks good i want to do the same to my 91-92 rs rims. Now go grab some armor all and spray those tires to set it off right.
http://www.pjtool.com/jewelersrougep...gcompound.aspx
actually not the best stuff to use... you should start with the white stuf, then move to the green.. red rouge is used mainly for fine jewlery, but it was what I had here
ambainb
04-25-2016 09:21 PM
kah992
08-19-2015 02:55 PM
