17" x 11" Rears Fit?
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
simple question, will a 11" rim fit the rear well? i'm sure some pounding would be in order but even with that will they fit?
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: 17" x 11" Rears Fit?
I have a 17x11 on the rear of mine. I'm running (i think) 1.25 or 1.0 rear spacers. They fit ok. Lil banging n the inner well and some coating. Also if you have rear disk's the caliper dampers are in the way and you may want to run tubular rear control arms. The lip of the fastory control arms get in the way. They come out to about the lip of the fender and dont stick out.
ambainb
04-25-2016 09:21 PM
I'llrocya
02-02-2016 11:43 PM
hectre13
08-26-2015 08:17 AM
