17'x9.5 C5 wheel fit with C6 12.75 rotor ?
Car: Firebird 91
Engine: Vortec 350 224/230cam, ported head
Transmission: TH700r4 with vette servo,hd oil pum
Axle/Gears: now 3.73 posi old 3.23 posi
rims like http://www.oewheelsllc.com/Corvette-...-p5939427.html , Brakes are C6 12.75 ? or i need 18 ? thanks
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Re: 17'x9.5 C5 wheel fit with C6 12.75 rotor ?
1 Post
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
The base C6 corvette uses the same front brake package as all the C5's. Rotors are the same, calipers are the same, abutments are the same, etc. If you are talking about the C6 Z06 (based on the rotor size you gave, you aren't), well that's another story. With the C6 Z06 brakes, you need at least an 18" wheel on the front.
Car: Firebird 91
this calliper i will install
1 Post
Car: 1987 IROC-Z
Transmission: TH350
That's what I'll have on the car in a couple weeks. The 17" wheels will clear it no problem.
Johnny Blaze
05-17-2013 07:53 PM
Scott_92RS
12-14-2002 09:41 PM
