BMW M-Sport 18" rims installed
1 Post
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
So,
In the quest for ever improved handling, I finally decided to leap off the cliff and get the good stuff. I'd been planning a 17" or 18" set of Torq Thrusts for a while, but I came across a great deal on these, and I just had to see how they would look. I've still got to figure out the center caps, but they'll be staying for good.
Specs:
Rims from a 2001 BMW 740iL (Known as the M-Sport Parallel design)
New Continental DWS Z-rated rubber
Front:
18x8", 13mm ET
245-40-18
10mm spacer
Rear:
18x9.5", 25mm ET
275-40-18
Factory .187" spacer
Let me know what you think. Personally, I love 'em.
-Levi
Specs:
Front:
18x8", 13mm ET
245-40-18
10mm spacer
Rear:
18x9.5", 25mm ET
275-40-18
-Levi
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
Re: BMW M-Sport 18" rims installed
I think they look really, really good man, very nice!
1 Post
Engine: L98/454/M20
I liked the staggered setup with the slightly taller rear tires, gave it a more aggressive stance without lowering. I thought real hard about 275-35-18 in the back, but that would have made it just a hair shorter than what was in front. In my opinion, those big rear wheel wells have always looked a little funny with the same size tires as the front. Plus, as an added bonus, I got some ground clearance aft of the front floorboards. I was getting sick of dragging exhaust pipe on speed bumps, not a problem anymore.
-Levi
-Levi
Car: 1992 GTA
Axle/Gears: 4.10
Your exhaust needs to come up a few inches tighter to the car. If you look in this pic you can actually see daylight on the top of the exhaust which indicates it needs to tuck up. Once its up even a nice 1.5 inch drop would give the car a great stance.
By the way the rims look very good on the car!
Car: 87 GTA
What springs do you have? I don't think I've ever seen a 3rd gen that sat so high.
1 Post
Engine: L98/454/M20
Believe it or not, the exhaust doesn't Go any higher. I took it to the shop after I got it put on, and they said that there was no way they could run the Y-pipe any tighter than it already was. The picture I posted is kind of deceiving, it doesn't actually hang as low as it looks, somehow I got the angle at just the point where it looks really, really low. I've got a shot from a slightly different angle that shows the pipe tucked up a lot higher where it's actually at. I dunno, weird...
I think the height of the car is due to several factors. It's got WS6 springs and KYB shocks, that's one factor, along with the taller than factory tires. It's also very light. The guy who had it before me weighed it in at 3150, and that was before the 4th gen seats, aluminum driveshaft, aluminum waterpump, and some other various lightening moves. It's carbed instead of TPI, so that saves some additional weight, and there's no emissions stuff left on it either.
You guys really think it needs to go lower? I reckon I could go with lowering springs, but don't you ever get tired of dragging the nose going into driveways? That was the problem I used to have with my T/A, it drove me crazy.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I really like the wheels. I have waiting for a good deal on some BMW wheels.
Car: 87 GTA
I got some stock height measurements from a couple of other GTAs, 1 with brand new WS6 springs, to see how much I lowered mine.
We'll compare it to the OEM stock height.
But as far as whether or not YOU should lower YOUR car.....That has to be a personal choice. If your roads or diveway won't allow a lowered car to drive safely, then don't lower it. Don't sacrifice the car, just for looks.
Car: 82 T/A 47,XXX
Engine: 305 until the ZZ4 355.
Transmission: turbo200
Axle/Gears: 3.42's
did you have to change wheel studs? and what about the spacers up front? i have stock suspension and am looking into it.
1 Post
Engine: L98/454/M20
No, I didn't change out the studs, but I wouldn't be comfortable running anything more than a 10mm spacer without longer wheel studs. I plan on doing the C4 disk brake conversion in the spring, which will put the offset just right on the front so I won't need a spacer at all anymore. Not sure about the rear, I may just leave it the way it is. It ran just fine without spacers, I added the little ones just as an added safety measure against rubbing on the inside.
I'll get the measurements when I can, the car is parked 3 miles away and I won't even see it again til this weekend. I'm interested to see how high it actually is.
-Levi
-Levi
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
What a hot car. Can i get that extra spicy. My buddy has those exact rims, i definatley gonna snag em from him one day when he is not paying attention
do you know what they weigh by chance? Facotry wheels are usually pretty light.
looking for a lightweight option for 18s besides Vette wheels.
thanks.
thanks.
1 Post
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I'm loving the look of the inset wheel. If the made those 1" wider I might have to get me a set. I need 10.5" wheels. I agree, it should be lowered an inch. Then it will really pop.
1 Post
Engine: L98/454/M20
I couldn't give you an exact weight on them, never had a chance to put them on the scales, but I can tell you that they're pretty dang light. There was quite a difference between them and the 15x8" that I took off. They compare favorably to the 16x8" factory rims too, I've had them on and off a few times, and it's a lot easier to lift up those 18" rims.
-Levi
-Levi
1 Post
Car: 89 Formula TPI
Engine: LB9
Transmission: WC T5
Axle/Gears: 3.73 posi locker ls1 discs
Man they look REALLY NICE! If it were me tho I would lower it to, but still looks great
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
Even without a lower suspension, I think those wheels fit your car perfectly... Droppin' it a lil tho would give it a few extra boner points... haha
Car: 87 GTA
Do you REALLY think it is that easy to cut them in two, add a strip in (or like mine, cut 4 wheels to make 2), weld it all back together STRAIGHT, and get a balance-able product? AND has a strong product? Welding aluminum is voodoo to half of the people as it is.
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
sure it goes up!! I have true duals passing from there and they are close to the floorpan so I have no issues with the lowered car!!
floor to front lip 25.5"
floor to rear lip 26.5"
1 Post
Car: 1987 IROC-Z
Transmission: TH350
Sorry Stephen... I guess I mis quoted you. I was only referring to the last sentence that said, "Gotta pay to get what you want." I know it is not easy to widen wheels unless they are 2 or 3 piece, but for a lot of other stuff, it is often times WAY cheaper to make the item yourself. I was just disagreeing in general, not specifically about the wheel issue.
Mike
Mike
1 Post
Engine: L98/454/M20
Manovox,
Those figures would leave my wheels tucked up inside the wheel wells themselves, they're both about 1/4" less than the height of the tires themselves? That'd be at least a 2.5" drop, maybe more. How on earth do you drive your car at that height without dragging over everything?
-Levi
-Levi
Car: 1987 GTA
Transmission: 4L60e
Looks really nice! Questions: Where did you get the 10mm spacer? Any idea which cars came with the "factory spacer" you mention (mine doesn't have any)? Any issues with the wheels being the 5x120 bmw pattern and not the native f-body one?
1 Post
Engine: L98/454/M20
Answers, haha:
1. The 10mm spacer is a BMW wheel spacer. Word to the wise, do not get the hub centric one for a BMW though. I ordered the double hub centric, but it would not fit either front or rear. I had to take it down to the lathe and have it bored all the way through. Let me try to explain this. The diameter of the inside of the spacer was correct for about the inside half (the side that contacts the brakes). But, when it necked down so that it could be hub-centric inside the wheel, this section was too narrow to go over the hub. Apparently BMWs don't use a grease cap, and the axle flange on the rear is also shorter, so you cannot fit on a spacer that is hub-centric to both the wheel and the axle, just the axle. Make sense?
I grabbed them off ebay, along with the little rings that fit inside to perfectly center the wheels on the hubs (72mm outside diameter, 70mm inside diameter + or - a few tenths on each) This'll help stop any vibrations. Get these off ebay too.
2. The factory spacer on the rear was introduced when GM swapped from the aluminum rear brake drums to steel rear brake drums, which were thinner and moved the wheels slightly inboard. They can now be found on a hodge-podge of cars, there's no real rule as far as anyone can tell as to which cars got them and which didn't. I would recommend sourcing a 5mm spacer for the rear just like the 10mm for the front. The .187" spacer is minimal, it helps, but more would be better. You can only just barely fit your fingers between the tire and the inner fender with a little bit of massaging involved. When I do the C4 1LE hub brake conversion, I'm going to move the 10mm spacer to the rear to help balance things out even better.
One word about the spacers, I wouldn't recommend going anything more than 10mm unless you get one of the 10 lug designs that can be found in 20mm on up. (spacer bolts to hub, wheel bolts to spacer). With the factory lugs and these wheels, there is enough thread engagement with a 10mm spacer, but I WOULD NOT go more. Also, make sure you double and triple check the torque on the lugs after driving for a while. Because there is less thread engagement than without a spacer, the lugs will have a greater tendency to loosen until you get them set in well.
3. The wheel pattern? not a difference, they fit on like they're made for it. BMW is a 120mm bolt pattern, 3rd gen is a 120.625mm bolt pattern. That's about .3mm of difference on the lugs, much less than is introduced by incorrect tightening of even a correct bolt pattern. If you're worried about it, tighten the lugs to full spec while the car is still off the ground using a star pattern, to make sure the wheel gets perfectly centered. Heck, you can even do it in several stages of increasing torques to make sure she's perfect. Get somebody to hold the brakes while you do it, and it'll be spot on. That's how I did mine, and they are glass smooth at 105, haven't run any faster than that yet.
Any more Q's, let me know. Also remember, you don't even have to run spacers at all, I just think it made it look even better than it did without them. Your call.
-Levi
-Levi
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
So,
Specs:
Front:
18x8", 13mm ET
245-40-18
10mm spacer
Rear:
18x9.5", 25mm ET
275-40-18
-Levi
Specs:
Front:
18x8", 13mm ET
245-40-18
10mm spacer
Rear:
18x9.5", 25mm ET
275-40-18
-Levi
Car: 1991 camaro z28 convertible
Engine: 383 tpi
Transmission: t5
wow that car is soo nice..i cant beleive bmw wheels look that good. a small drop would look a little better but it looks good the way it is too......awsome car man!!!!!!!!!!!!!!!!!!!!!!
-Levi
-Levi
good job.... she looks great
Car: 1987 Camaro Sport Coupe
Engine: 3.4L V6
Transmission: T5 (NWC)
Axle/Gears: 3.42 Stock axle
I like the wheels and I think the car sits OK. I never got the whole lowering thing on these 3rd gens. But I guess I see them as 80's muscle cars not high-tech 90's street machines.
#43
#45
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
I am drooling....I love BMW wheels. And it looks like these will fit right on as well: http://austin.craigslist.org/pts/1500544125.html
Those would be gorgeous with a lowered formula....
#46
Car: 1987 Trans Am
Engine: LQ9/L92
put me on the list too; wow do those look good. I think I have another set of rims to add to my wishlist now...
#47
I did some digging, trying to find out what those wheels are. So far I have found a couple designs. Mostly BBS made:
Those look kind of like the ASA wheels made by BBS and sold at tire rack:
http://www.tirerack.com/wheels/Wheel...ip&showRear=no
I am still looking around as, obviously that is not the exact wheel. I should have jumped on them when I saw the for sale ad.
#48
Car: 87 GTA
I was gonna get ASAs to replace my crosslace wheels, until I got the chance to get my Snypers.
#49
Figured it out, the ad is gone of course, but they are E38 BMW "M cross spoke wheels", or sometimes reffered to as "Y" spoke wheels. I am having trouble finding any, but those are IMO the perfect wheel. Having a hard time finding them in a fitament that will work with our cars though. I blame the OP for my new obsession.
#50
Car: 1990 RS convertible V8 auto
Engine: 305 Tbi
Transmission: auto
I been doing some research on these wheels. They are BMW M5 2000-2003 made by BBS. fit our cars perfect without spacers or adapters.B.S. is ideal also for 305 rears and 285 front
