Mods to replace 15 inch wheels with 16 inch
Hey guys will I have to do any modification to put 16x8 inch 88-92 Formula wheels on my son's 86 Firebird with 15's currently on it. Will it increase or decrease my tire choices. Thanks for your help.
Car: 1990 Camaro ZRS
Engine: 350 SBC
Re: Mods to replace 15 inch wheels with 16 inch
the wheel should fit perfect. however on your tire choices will limit you to a lil shorter of a tire.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
the 15" came with 215/65/15 tires if i remember correctly. if you want to have a correct speedo reading, you'd need 245/50/16 tires like the stockers, or use these two links to find equivalents:
http://www.miata.net/garage/tirecalc.html
http://www.dsm.org/tools/tiresize.htm
oh btw i was wondering if there was anything else you should swap, like the chassis suspension bumper stops? they are different for the 16" wheels imho
1 Post
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
i got a T/A 85, the info about the car on this said i should have 16's. i got 15's now, so i should upgrade? im thinking im getting jiped on the odometer because of having non stock 15
Car: 87 GTA
Bigger rim = shorter sidewall, for the same overal diameter.
