Spare tire replacement
1 Post
Car: '89 Iroc-Z
Engine: 5.7 TPI
Transmission: 700 R4
Axle/Gears: 2.77
Hey there guys,
I hope anyone reading this can help me out on a problem with my camaro's spare tire.
I have an '89 iroc-z with the 5.7 TPI motor. This January, one of the tires went flat...no biggie. When I went to change the wheel, I used the cylinder to inflate the spare/compact tire.
The tire inflated unevenly and was bulging at different points. Needless to say, it drove very wobly. My brother, who was driving behind me, said the tire looked as if it was about to come off of the wheel.
I took no chances and parked the car and simply took the flat tire to be replaced (Yup, it needed it).
The following day I called several tire centers and was told that the spare is a dealer-specific item. After having called the dealer, they told me that it was discontinued.
I've been driving since then with no spare. I really don't want to carry a full-size spare because of the Bose sound system. I'm sure it'll get in the way.
Any help is appreciated!
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Re: Spare tire replacement
If you weren't so far away i would give you mine.
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
or use the new GTO compact spares... i hear they are the same size but much thinner and will fit just fine
I've just visited this forum. Happy to get acquainted with you. Thanks.
________________
Free Anime Episodes
According to post 19 and 21 of the following link, a fourthgen spare will fit:
https://www.thirdgen.org/forums/brak...4th-gen-2.html
JamesC
JamesC
Car: 85 Camaro IROC
Engine: 5.7 TPI
dont take it as fact, but ive heard it in various threads on here and as we all know... if its on the internet, it HAS to be true... the internets don't lie right?
Car: 1969 RS Z28 X33 Norwood built
Engine: 383 Stroker
Transmission: T10 4 speed
I have the collapsed spare and was wondering if anyone actually used theirs. This answered my question. But it sounds to me like this is a lousy spare. I guess I'll just hope I never need one.
Mine did the same thing when inflated. I think that they are so old, and been compact for so long, they just started to deform. If you buy another, inflate to check, and hope you can get it back to deflated shape.... fix a flat is messy, but is an option... and with a 12v air cimpressor, a bit smaller than spare tire...
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
2 Flat 2 Go
The Space Saver spare fits inflated in the right rear area intended in all the 3rd Gens I’ve seen and have.
Happy Racing!
Don’t Blame Me For Spinning You, My Car Simply Took The Air Off Your Spoiler
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
it sounds to me like the canister was low on air ... my spare inflater all crazy like that too.
as old as it is, i was afraid to put much air into it and it was all misshapen and crazy looking, but after the 5th time i got scared and let all the air back out of it i just said f*** it and went for it ... once i got it to full psi, it was fine (was glad i didn't need it though, one that old scared the crap out of me) i just needed to have one for a road trip i was going on and didnt want to be stuck on the side of the road with nothing
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: 2 Flat 2 Go
[QUOTE=
[/QUOTE]
not in the verts.i have to wrestle mine out of the hole even with the valve stem removed.
[/QUOTE]
I run gto spare wheels with m&h front runners as my drag skinnies. Work great and clear 13" brakes! Perfect spare for guys with brake upgrades
Since i got two i can keep one as spare for my iroc and one in my 4th gen as spares that are lighter than factory
Thanks Orr I will try to find a GTO spare tire.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Heads up = Do not run your car with a donut tire in the rear if you have a posi unit. It will rotate at different speeds and is very hard on any clutch pack unit. I'm not sure about the lockers.
I have a 92 convert and tried my spare. It was all over the place. Apparently the age is the reason so I don't see any sense buying an old spare to replace it. Has anyone found a tire that could be mount to the spare's rim? We know the rim has the right clearances since the front and rear wheels are different. I would like to put a fresh tire on there (even if fully expanded/inflated) rather than using another older tire (gto).
1 Post
Car: '89 Iroc-Z
Engine: 5.7 TPI
Axle/Gears: 2.77
It doesn't seem like 5 years ago that I started this topic! Lol
I went with a 4th gen Camaro spare, as they are more readily available than 04-06 GTO spares.
1992rs/ss
05-19-2020 07:02 PM
colton_carlson
03-08-2019 12:21 PM
1992rs/ss
16
01-28-2016 09:58 PM
