Got Vette Wheels??...Post pics here...!
#351
Car: 91 Firechicken
Engine: 355ci SBC
Transmission: 97GM BW T-56
Axle/Gears: 9", Moser 31 Splines 3.73s Trac Loc
Re: Got Vette Wheels??...Post pics here...!
A spacer slides over your studs. You have to get longer studs to make them work properly. An adapter has 5 holes just like a wheel to bolt to your hub AND it's own set of lugs coming from that to bolt you're wheel to.
#352
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Is it a must to have adapters? I have y2k rims and want to mount them on it.
#353
1 Post
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
yes, it makes up for the different back spacing on the vette rims. I have 2 inch adapters/spacers all four wheels.
#355
Car: 91 Firechicken
Engine: 355ci SBC
Here's mine:
#356
1 Post
Engine: 400
Axle/Gears: 3:73
They are really called adapters. You will find them all over fleebay. If you look you will see they bolt to hub/axle and they have their own lug nuts. With all the postings on this subject and you still don't understand it, you better stay away from doing it. You take old wheel off bolt on adapter on, then put The new wheel on. Bolting it to adapter.
#357
Car: 91 Firechicken
Engine: 355ci SBC
Larry-that's a pretty different looking front end on your car in that pic. You got any more of it up close?
#358
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Anyone know what size adapter would be need on the front with a big brake upgrade using the 1le hub? I know 2 inch would be too big, so im thinking 1.5??
#359
1 Post
Engine: 400
Axle/Gears: 3:73
The wheel backspace sets what size adapter you need. I.E. the c5 wheels on my TA needed 2inch to bring them out to clear the inside wheel well.
It is a Knight Rider bumper with a ram air 1 hood. Stock fenders.
#362
1 Post
Car: 80,81,85, trans am
Engine: 4.9,301turbo,350
Transmission: all auto
Axle/Gears: 308,342,308
i have another exact same set i want to use on my 89 formula. im hoping i can use a 295 on this wheel. what width wheel do you guys normally use with a 295.
#363
Car: 1987 Camaro Z28
Engine: 5.0 TPI
hi everybody, i just bought a set of 18x9.5 Z06 black with polished slip rims for my 87 Z28... does anybody knows if i will need something else to fix them on it and what's the size you recommend to use on it for a nice handle... i was thinking in something like 285/40/18 what do you thuink about it???
#365
Car: 90 camaro rs ttops
Engine: 350 tbi
Axle/Gears: 323
i jus bought a set of vette wheels front 17x8.5 and rear 18x19.5. i have a stock 90 camaro what size wheel spacers will i need? can anyone help
#367
1 Post
thanks guys. its a light weight wheel made in italy out of magnezium. light and strong. very rare to get wheels made out of this. burns white hot when you light them on fire
found on mid 2000 corvettes.
#368
1 Post
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
I have the same wheels but 10.5's in rear. I used 2in. In front and 1.5 in rear. I was told many things but these are what work with my car. Feel free to pm me.
#370
1 Post
Car: 1992 Camaro
Transmission: t-5
EBay... ones I got are great and high quality.
#371
Car: 89 Trans Am GTA
Engine: 5.7 350 TPI L98
Axle/Gears: Borg-Warner 3.27
Anybody have pics of open spoke Vette rims with stock brakes? I will be rolling stock brakes until I can upgrade to something better and I want to see how small the stock rotors look.
#372
update the brakes yet. Hell I just got it dropped
yesterday. 2" spacers up front with 4th gen disc
rear 'no spacers'. Here is a pic before the drop.
#373
I'm looking to run a set of c6 five spokes on my '89 gta, but i have a 5## c.i. big block, think the springs will be compressed too much to run an 18" up front? Think they will rub or no? any opinions welcome, thanks!
#374
ok i need some HELP!! i blew my wheel bearing out and i am trying to change them. i got the wheel out got the pin nut and washer out but the race that seats the bearins want come off!!! dose any one know how i can get it off? i cant get it to budge and idk if its just stuck or if it skrews on. PLEAS help reply to my email willg20@yahoo.com
#376
Car: '91 TA vert
Engine: turboLSx
Are you running factory springs? Either way, an 18" wheel isn't going to be any different than a 16" 17" 15" etc. The overall height with tire is what you want to pay attention to. And if you compress the springs in there the point of not being able to run a standard size tire you're going to be dragging the kmember on the ground. The bb doesn't weight THAT much more than an iron sb. Goodluck.
#377
Car: '91 TA vert
Engine: turboLSx
#378
1 Post
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
would 17x9.5 with 2" spacers in the front rub at all? and would 18x10.5 in the rear with 2" spacers and 3rd gen axle be good?
#380
the wheels your talking about are exactly what im gunna put on my iroc once i get the money for it and get a few other things taken cared of. heres the linc for it from oewheelsllc
http://www.oewheelsllc.com/Wheels-fo...02364-3-1.html
#381
Car: 86 Grand National / 90 Formula
Engine: 3.8 V6 / Procharged 5.7tpi
Transmission: 700R4 / 700r4
Axle/Gears: 3.42's / 3.23's
just got them on yesterday cars dirty but still looks respectable.
#383
#387
Yes they are brembos, big reds off a 993 TT most likely. Same as I have on my Corvette from MovIt
3genpio, where did you get the adapter brackets?? Those calipers are radial mount, did you sue a radial to lug mount adapter?
#388
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Those are nice brakes Twin_Turbo how are those brake pads ive heard that they have 6 different pads is that true?
#390
Car: Trans Am
Engine: 383 Accel ProRam single plain EFI
Transmission: t-56 Spec #3
Axle/Gears: 4 gen 3.73:1
there is plenty room in 18"
i gues i have somewhere the diagram with messurements if someone need it.
#392
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Those are the exact same brakes i have, now i know they fit and how they look thanks alot
#394
The ones in my pic are big red 4 pot brembos, back then they were some of the biggest and best brakes out there. That's over 10 years ago.
So those are the CTSV calipers, nice! I like that, especially since they are lug mount. Radial mounts get expensive when you have to do custom brackets. Only problem, I have 17" jongbloed wheels...them thar puppies ain't gonna fit
#396
Car: 1988 Camaro
Engine: 2.8L V6
Transmission: Automatic
Here are mine. The car is a work in progress but i have 18x10 back 17x8.5 front. 2" spacers on back and 2 1/4" on front
#399
Car: 1988 Camaro
Engine: 2.8L V6
I had the same dilemma zr1 or c6. i like the way the back wheels look on my car but I with the front were 18 also. I am going to get wider tires for the front nonetheless next time.
#400
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
finally got my on 18/19 combo, 2" spacers all round
(bright chrome lugs are temporary )
